puurty = pretty
I’ve got a project coming up that will use a bunch of redwood to create an outdoor structure that will be put up for about two weeks of the year, the rest of the time it will be in storage behind a building.
I will be making a specialized storage system for it – it will not be sitting on the ground!
My question is this: How do I keep that wonderful color of redwood looking new so it doesn’t bleach out over time? My other concern is with bugs, the finish can’t be tasty to them as we have airborn termites here.
Also a CRX fanatic!
Save the Whales! and Guns!
the only solution you need is Sikins, Cetol 1 & 2,3 plus
Use both products together, or one or the other?Rebuilding my home in Cypress, CA
Also a CRX fanatic!
it's a 2 step process Cetol 1 is the first coat, Cetol 2,3 plus 2nd, 3rd and maintenance coats. They are replacing it with a 1 coat product, shame, I've got a small stock pile of Cetol ..
If you REALLY, REALLY want it to stay absolutely puurty, make a cover for it. Keeping the sun off of it is the key.
Redwood won't bleach out, but it will turn grey when exposed to the sun. The longer it sits in the sun the darker it gets - often pretty black.
Since your project wll only be exposed a couple of weeks each year, pretty much any "clear" finish should be fine - particularly if you can touch it up every couple of years. Make a few samples from some scrap and try polyurethane, linseed oil, lacquer, and whatever else you like. They all look great.
Termites shouldn't be a problem as long as you use only heartwood (the red part). The white sapwood just provides a free meal for the little buggers. I've pulled redwood posts where the sapwood was completely gone and the heartwood looked like it had been cut yesterday. - lol
If you have the time, you can save a few bucks by buying conheart lumber and let it dry for a few months. Otherwise, be ready to spend some serious money for clear, KD, lumber.
"Redwood won't bleach out, but it will turn grey when exposed to the sun. "When wood greys off from the UV rays, it is CALLED solar bleaching
If this is going to be protected from the weather for 50 weeks of the year I would vote for using NOTHING.Then after, maybe 10 years it might start showing some weather then use a deck brightner..
I thought of that. I'd want to see more of what the structure is and how used to know for sure. horizontal surfaces will let water grow mildew. Intricate details would make it harder to sand it off again....
Something for the Festival of Tents?
It's for Sukkot, Where the structures are supposed to have holes in the roof.
Apparently Jewish building codes were pretty lax.
I'm working up the design at the moment, might be a good time to learn Scetchup!
When up, it will be be on a 22'x22' footprint, and be 12' to 14' tall at it's peak. I'm modeling it on elements of the temple itself. The whole thing will break down, some elements folding together for storage.
My design challenge is that it should be relatively easy to piece together from instructions, and ideally be assembled without hand tools.Rebuilding my home in Cypress, CA
Also a CRX fanatic!
tents ~ tabernacles apologize for misremeber the right terminologySince the temple was modeled on the tabernacle and it liberally used cedar, would not red cedar be a better choice?Is this a family hut or is a larger congregational kind of thing
Cedar might work , if I could find it in conventional lumber sizes.
This is something for the whole congregation - mine is only 12'x12'Rebuilding my home in Cypress, CA
Also a CRX fanatic!
I am a lot further from the source than you are and I can get any size red cedar I want as long as I pay 6-10/BF for it.I find it lighter, stronger, and easier to work than redwood. And probably less sappy.
Plus I like the smell.
I'll look into it, thanks!Rebuilding my home in Cypress, CA
Also a CRX fanatic!
