Keeping the white in white pine
| Posted in General Discussion on April 6, 2000 04:19am
Another vote for white pickle. Had a friend who wanted to keep the look of new pine on paneling. She did it by mixing one quarter cup of white paint into a quart of varnish. That was 20 years ago, and the walls still look like new pine. The grain is clearly visible, but the walls have not taken on the orange of aged pine.
With the new coating options available you should be able to find a pickling stain.
  1. Gary_Switser | Apr 07, 2000 09:14pm | #4
    I would also like to know the "trick" of getting a truly white whitewash. After several trys (different projects)at a semi-transparent "white" whitewash with all of the suggestions above, I'm still dissapointed, or at least, not getting what I expect. The soft portion of the grain takes the tint fine but the hard portions (as I call it)of the grain and knots retain the yellowish tint or bleed through enough to not give a uniform white. The wainscoating room we whitewashed with pickling, and waterbase clear urethane topcoat, has a pale yellowish tint.
  2. Guest_ | Apr 07, 2000 09:14pm | #5
    I am applying white pine v-match to a ceiling. I love and wish to maintain the fresh whiteness of white pine. How is this done? I plan to finish with poly (water-based) - is that sufficient? Do I need to look for poly with UV protection?
    1. Guest_ | Apr 04, 2000 03:35am | #1
      *Try a water-based coating with UV protection. I've had good luck with Crystalac which is very neutral, transparent, and sprays well. Any wood will darken a little regardless . You can get it from McFeeleys, email me if you need that number.JN
      1. Guest_ | Apr 04, 2000 03:41am | #2
        *White pickle.
        1. Bob_Karrow | Apr 06, 2000 04:19pm | #3
          *Another vote for white pickle. Had a friend who wanted to keep the look of new pine on paneling. She did it by mixing one quarter cup of white paint into a quart of varnish. That was 20 years ago, and the walls still look like new pine. The grain is clearly visible, but the walls have not taken on the orange of aged pine.With the new coating options available you should be able to find a pickling stain.
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
