Kerosene heater with outside tank question
Seabae | Posted in Energy, Heating & Insulation on January 29, 2023 02:51pm
Hello, my mom just bought a house/cabin that has a kerosene tank outside, ive noticed on the tank where the pipe is attached it looks wet like a round 6 in damp spot and smells a little also the metal pipe with pvc around it looks greasy. She says she had a kerosine guy come check it out and he says its not leaking but on the tank itself the old owner drew chalk marks showing with dates measuring i guess how empty it was over the years one date being 1995 and another 1998. I read on here someone mentioning a “wet tank” can someone explain that to me and if its something to be concerned about also is it okay the tank is that old? Thank you
  1. mgmahan | Jan 29, 2023 06:49pm | #1
    For LPG a wet tank refers to a tank that is used to fill other tanks. For example if you have a propane vehicle the wet tank is used to fill the vehicle. I don't know about kerosene.
Old House Air-Sealing Basics
