Kitchen cabinet crown molding
trombec | Posted in Construction Techniques on July 9, 2006 06:33am
I have installed kitchen cabinets & I want to install a 2 piece molding.. First a flat furniture piece then a 3″ crown. I need advice on installing a backer piece on the cabinet. Also, what do I do with that small edge sticking out on the upper cabinet where I make the outside turn.
Thank you
    basswood | Jul 09, 2006 08:12pm | #1
    Trombec,
    There are several ways to do this. The flat molding can stack on top of the cabinet and project out past the faceframe a bit, or it can lap over the faceframe (unless you have full-overlay doors). I the first case, I put a 1x2" nailer back 1/4-3/8" from the faceframe. In the second case, the nailer is flush with the faceframe.
    --"Also, what do I do with that small edge sticking out on the upper cabinet where I make the outside turn."
    I usually notch for moldings with a pull-saw and a sharp chisel (unless the molding is so small that it looks like it was swallowed by the notch).
    Here is a pic of a more eloborate version of what you are doing...I hope you can see how the vertical molding is seated into the notch.
  2. FHB Editor
    JFink | Jul 11, 2006 04:23pm | #2
    I was up pretty late last night, and I'm draggin @ss this morning - but I just can't figure out what you mean when you say:
    What small edge?
    Justin Fink - FHB Editorial
    Your Friendly Neighborhood Moderator
    1. JulianTracy | Jul 11, 2006 04:31pm | #3
      He's talking about the face frame edge at the side of the cabinet, I think.JT
      1. FHB Editor
        JFink | Jul 11, 2006 04:43pm | #4
        ahhh, I see now. Thanks Julian.Justin Fink - FHB Editorial
