Kitchen cabinet hinges
und76xx | Posted in General Discussion on March 5, 2009 05:07am
I have to replace several failed kitchen cabinet hinges. They are European style hinges – I think. Hidden where the door portion is a circle type of apparatus imbedded into the door itself.
Manufacturer: Blum
Markings: 110 on one side and 1 1/4 on another.
A little black piece of plastic has broken in each hinge and consequently the doors will not stay shut.
Where do I find such an animal. They are probably @ 10 years old.
Thanks, Mike
    PaulBinCT | Mar 05, 2009 05:15pm | #1
    Any large woodworking store carries those hinges, Woodworker's Warehouse (or whatever it's called), Rockler's... just Google Blum.  I gather they are 110 degree, other than that you oughta be able to use virtually any 35mm cup style hinge they make.
    PaulB
    http://www.makeabettertomorrow.com
    http://www.finecontracting.com
  2. cliffy | Mar 05, 2009 05:27pm | #2
    Pretty much any of the big box outlets carry those.  However if you want service go to your local lumberyard or custom kitchen outfit.
    Have  good day
    Cliffy
  3. rondon | Mar 05, 2009 05:50pm | #3
    The 1 1/4 is the offset amount the door overhangs the face frame.  Make sure you get the same.
    1. und76xx | Mar 05, 2009 06:09pm | #4
      Thanks - I will avoid HD and go to a local carry-all hardware store. I did take your suggestion and look on-line. Now that I see the options this is not going to be difficult.Thanks again, Mike
  4. Pelipeth | Mar 06, 2009 03:47am | #5
    I would recommend a local cabinet shop.
  5. JMadson | Mar 06, 2009 03:56am | #6
    http://www.leevalley.com/hardware/page.aspx?c=2&p=55420&cat=3,41241
    "Political correctness is a doctrine, fostered by a delusional,
    illogical minority, and rabidly promoted by an unscrupulous
    mainstream media, which holds forth the proposition that it is
    entirely possible to pick up a turd by the clean end"
    R. J. Wiedemann LtCol. USMC Ret.
    1. Catspaw | Mar 06, 2009 04:24pm | #7
      This site is a great resource for identifying the correct hinge:
      http://www.cabinetparts.com/hinge-replacement/
      - Rich
      1. und76xx | Mar 06, 2009 04:35pm | #8
        That is nothing but neat. I will tell you the answer - I completed the Q&A portion and now I await my hinge before I become unhinged or something like that.Thanks!
