Kitchen cabinet installation question
Houghton123 | Posted in Construction Techniques on July 11, 2007 05:43am
I’m installing some Omega Dynasty cabinets in our kitchen, and find the factory instructions odd.  They have me drilling a 7/32″ hole for a #8 drywall screw.
First off, I’m not using drywall screws – I’ve snapped off too many.  I’m using Fastap instead.  So no need to tell me not to do that.
Second, and the reason for this message  – 7/32″ is practically the size of the head, and I drove the first screw all the way through the rather soft plywood back.  Any idea why they want me to use such a large hole?
  1. apiersma | Jul 11, 2007 06:03am | #1
    My guess, and that's all it is, is to ensure you don't damage the "soft plywood back" by forcing a screw through the wood. Try some smaller holes and see how the cabinets install.
  2. Novy | Jul 11, 2007 06:03am | #2
    Google washer head screws
    On a hill by the harbour
  3. Geoffrey | Jul 11, 2007 06:30am | #3
    That hole is just a clearance hole thru the cab. back, ........ try using either a finishing washer with your screws or going to a cabinet screw or washer head screw or truss head screw, all have a larger head to prevent them from being pulled through the cab. back like you describe.......using a 1/8" x 6" long bit for a pilot hole into the studs will help when driving the fasteners......and use a #10 screw.....stick w/ the 7/32" clearance hole........
    Did the cab. maker really say to use a drywall screw? Shame on them!!
        Geoff
