Kitchen Cabinets
SJoseph | Posted in Construction Techniques on February 6, 2016 12:19pm
I am planning to build new kitchen cabinets. It’s a small kitche and will have only one row of cabinets. A free standing stove will be at the end of the row and in the corner of the room. How much room should I allow for the stove, the exact width of the stove or a little extra? If additional space is needed, how much? Thank you for your input.
Steve
  1. calvin | Feb 06, 2016 02:27pm | #1
    Sj
    stove in corner?
    wall next to it?
    bad idea especially if a gas range.  Fire hazard.
    Cookingwise?  You should have a minimum 12" of counter to either side of the range for prep, cooking and soup ladeling.....
    you know how you cook, what you need for comfort.
  2. DanH | Feb 06, 2016 02:39pm | #2
    In our kitchen the space for the stove is about 1/2 inch wider than the actual stove -- a quarter inch on each side.  But things are pretty straight and square -- if the walls aren't straight or the cabinets will be hard to set exactly right then you'd need more.
    And what Calvin says -- a stove should never be up against a side wall.
  3. mark122 | Feb 06, 2016 06:56pm | #3
    I wouldnt give it more than a 1/4", 1/8" on either side is plenty of clearance.
  4. finefinish | Feb 08, 2016 09:52am | #4
    Hey Steve, Check the range specs.  It will have a cut out dimension.  In general, a 30" range requires a 30" cut out width (space between cabs), a 36" range needs 36", etc., etc.  The actual appliance is usually undersized just slightly.  Adding extra width is not necessary and will look unprofessional.  These standards I outlined are for "slide in ranges".  "Drop ins" may have different width requirements.
    Mike_Mahan | Feb 08, 2016 10:46am | #5
    Subject Line
    When you put "kitchen cabinets" in the subject line of a post 90% of the people on this forum will ignore it.
Two Ways to Test Windows
  • The New Old Colonial
