We are remodeling our kitchen and having new maple cabinets built. We wonder if melamine constructed drawer boxes and roll outs are a good choice.
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
I wouldn't. In drawers where there's weight and collision, don't think it would be a good value decision. In roll out trays, a week bottom will sag over time, and in the case of canned goods........ Moving parts I don't think a good idea with melamine.
What does your cab guy say about it?
Quittin' Time
Melamine is the cheaper alternative (for your cabinetmaker).
I don't think strength is really an issue. Melamine stands up pretty well to surface abrasion under normal use; but if you are using a tray for pots and pans, and sliding them in and out, the Melamine will probably show signs of wear faster than a varnished wood surface.
Some customers like Melamine interiors because they like the look and the surface can be wiped down easily. Not that varnished (or lacquered) can't be wiped down, but some feel the Melamine surfaces just look "cleaner."
I would ask your cabinet guy what the alternatives are, and the prices for each.
"I would never die for my beliefs because I might be wrong."
-- Bertrand Russell
The most popular type of mat'l used around here is 1/2" baltic birch. Its a little more expensive but durability and appearance definately make up for the cost.
Caution: This message may contain "For Official Use Only" (FOUO) or other "sensitive information" is not intended for non-official disclosure. Do not disseminate this message, except to persons who require it for official Breaktime purposes, without the approval of the individual originating this message or other authorized official of the Taunton University. If you received this message in error, please delete it.
I would go with 1/2" baltic birch, or 1/2" hardwood, box joint or dovetailed. Make sure they don't use 1/4" bottoms on any roll outs wider than 15". If you would settle for melamine, why pay for custom built cabinets?
