Kitchen cabinets on SIP’s
thomas61 | Posted in General Discussion on February 25, 2006 04:32am
I’m in the design stages of a home in northern New York, (Lowville). For energy efficiency I am considering either stick built with spray foam or SIP’s. Both seem very good, prices are competitive, but I am wondering on the SIP’s, how do you hang kitchen cabinets on an exterior wall? What structure must be added if any?  It is a ranch home with a full basement so would the electrical have to run up from the basement at each outlet and switch then back down to meet another ? Also, I am going to use 1″ tongue in groove throughout, will nailing on the tongue hold in the osb to keep the joints tight? Any help would be appreciated. Thanks
  1. iluvgear | Feb 25, 2006 05:12am | #1
    Depending on who manufactured the panels, there may be a nailer embedded in the foam to hang cabinets.  As for wiring, some panels come with precut chases or a hot knife is used to cut them where needed.  I am sure those with more experience will give more details.
Mortar for Old Masonry
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
