I plan to install 1/4″ 4X8 sheets of beadboard on strapping that has been installed perpendicular to the ceiling joists. Is the beadboard, generally speaking, up to the fire code (generally speaking)? Should I sheetrock first then install the beadboard? Appreciate the help. Habs
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
Most assuredly hang the drywall first, and fire tape at the minimum. That beadbd isn't masonite I hope? How big is this project and how do you plan to deal with the seams on the ends?
