Kitchen drawer slides
| Posted in General Discussion on August 17, 2001 02:37am
I need to select slides for 20″w x 22″d x 8-10″h drawers that will hold
pots & pans and can goods. The cabinets have face frames. I’ve been
considering these full extension models.
Ball bearing side mounting
Accuride 3832 (100lbs)
Accuride 3832SC (100lbs, selfclosing w/spring?)
KV 8400 (100lbs)
Roller bearing corner mounting “Euro” style
KV 1485 (150lbs)
Is a 100 lb slide o.k or too much or too little?
I haven’t seen the closing action on the 3832sc, how does the closing “feel” compare to the “euro” stlye closing?
Is the KV1485 less or more stable in lateral movement than the others?
Should I mount the rear brackets to the 1/4″ back or should I add 3/4″ vertical material to the back for bracket mounting?
I’d appreciate any words of wisdom and comments?
Mike
  1. Mike_S_ | Aug 17, 2001 02:37pm | #1
    I need to select slides for 20"w x 22"d x 8-10"h drawers that will hold
    pots & pans and can goods. The cabinets have face frames. I've been
    KV 8400 (100lbs)
    Roller bearing corner mounting "Euro" style
    KV 1485 (150lbs)
    I haven't seen the closing action on the 3832sc, how does the closing "feel" compare to the "euro" stlye closing?
    Should I mount the rear brackets to the 1/4" back or should I add 3/4" vertical material to the back for bracket mounting?
    I'd appreciate any words of wisdom and comments?
    Mike
