Got a leaking faucet and the new washers to fix it, but I can’t get the spout off of the base. It is not frozen; the spout swings back and forth between the two sinks. It just won’t lift/pry/wiggle up and off.
Is there a special wrench or whatever to lift faucets?
Janet
If your picture is correct, did you remove the cartridge screws?
Yes, I have removed the screws. It's only the blue-colored parts that need to be separated.Janet
I didn't know they sold those in blue. Now I want one!"There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."Will Rogers
It wiggles off. Just rebuilt mine. Pull up near the base and rotate the spout back and forth. It should come right off.
There is two o-rings that seal it and have a fair amount of surface contact.
I use a lot of plumbers grease around those o-ring when I re-assemble it. I grease everything. Can't hurt.
Even with the grease it still seems tight.
Will Rogers
That spout should 'just' pull off. If the old o-rings have hardened, you may need to rock and turn simultaneously and apply more upwards force than you think, but it will pull off. Have a couple of faucets just like your pix, no special tool.
I usually use corn oil or margarine on the o-rings when repairing to allow for easy re-installation.
I figured it was a question of strength, so I asked my husband to try, but no luck. I even climbed into the sink so I could pull straight up! If the faucet swings freely, why is it so stuck?!I just heard some thunder...Is it dangerous to touch plumbing during a storm?Janet
Edited 7/2/2009 4:17 pm by jyang949
I always figured it's good to be well-grounded during a storm. Prevents static buildup.
As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
The faucet arm is stuck because the O rings are essentially "glued" to the inside of the faucet arm, while they turn freely in the slots in the valve body. You've got to break that "glue" bond (basically rubber stuck to metal and surrounded by a reinforcing layer of crud), and you do that by applying force (but gently).
Yup, pull straight up while rotating the spout back and forth. Lota force, lota twisting, but it will start moving eventually.
Remove lever set screw, remove lever and the trim ring.
Hose the space between the spout and cartridge with WD-40. Rap on the side a few times
Have a beer, go to dinner (read as "wait a few hours")
Wiggle, rock, yank some more --- it will come off.
"If it doesn't move and it is supposed to - use WD40."
Oft repeated utterance of a very wise man.
Jim
Edited 7/2/2009 5:16 pm ET by JTC1
I wouldn't advise WD40. Rubber expands when it absorbs petroleum solvents.
If they are that stuck, I assumed they would be nicked / torn / broken / destroyed in the disassembly process and replaced.
New ones get coated with plumbers silicone grease before assembly.
JimNever underestimate the value of a sharp pencil or good light.
Turn the water back on. Then wiggle it.
Cool
Wet T-shirt contest!A Great Place for Information, Comraderie, and a Sucker Punch.
http://www.quittintime.com/
Wasn't very nice of me.
It finally came off with the help of a "faucet-handle puller."
http://www.gp.lib.mi.us/information/about/t_faucethandlepuller.htm
Note: The puller I bought is not long enough for tall faucet fixtures. Don't know if pullers come in different sizes.
