Kitchen tile backsplash questions
JulianTracy | Posted in General Discussion on November 7, 2006 04:16am
Hello,
I had asked Custom building product’s (HD’s thinset/adhesive vendor) advice about which of their products I should use on a tile backsplash I was working on.
The surface is primed drywall – away from the sink, so no water problems, and they suggested their premium modified thinset with a 1/4″ x 1/4″ notched trowel.
I told them I was setting mosaic sheets of 1.5″x 1.5″ ceramic tile with 1/8″ grout joints and they still said they suggest the thinset product.
So, because I used the 1/4″ trowel – I spent a good couple hours getting all of the dried splooge from in-between the tiles before I could apply grout. I didn’t do it when it was wet cause I didn’t want to screw up the tile placement.
So, a few questions: With a 1/8″ grout joint – isn’t a 1/4″ notched trowel too large? It seems like when you use the thinsets – that’s as small as you can go with the notches. Whereas with tile adhesive – it recommends 3/16″ angled trowel notches.
And speaking of tile adhesive – WTF is it good for? The can says floors – be they tell you, no, don’t use it on floors… I was thinking it’d be great for the backsplash job but they said no, use thinset.
So what the hell do you use premixed tile adhesive for?
I know about the John Bridge forum, but there must be enough folks that do small tile jobs here for a bit of advice.
Thanks,
Julian
  1. CAGIV | Nov 07, 2006 04:22am | #1
    I'd have used mastic for a tile backsplash and with a 1x1 mosaic a 3/16" V-Notch.
    There is no reason why mastic wouldn't work for a backsplash so long as you do not plan on getting it soaked.
    Who ever told you to use a 1/4" square notch for 1x1 mosaic has never set tile in his life.
    I'd venture to say the same about using thinset, but there are some die-hards out there.
    Team Logo
  2. FastEddie | Nov 07, 2006 06:38am | #2
    I would have used thinset with a smaller notch.  But for a kitchen backsplash, even behind the sink, mastic would have been a good choice.
    Your first problem was asking the sales nut at HD, rather than looking at the Custom website.  Or the tile web site.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
