Kitchen water tap
Zack123Vip | Posted in General Discussion on April 19, 2020 11:27pm
Hey guys.  There is an issue with the kitchen water tap and I need your advice . The hot water works without any issue,however if I turn the handle to the cold water, the cold water will start then  stop within few seconds. I replaced the Faucet cartridge recently.  Any advice will be appreciated.
  1. florida | Apr 20, 2020 10:16am | #1
    The obvious first thing to check is your new cartridge and make sure you have it positioned correctly. Its easy to put them in wrong.
    1. Zack123Vip | Apr 21, 2020 01:14am | #2
      I checked the cartridge again, it's correctly installed. I noticed when I turn the handle to the cold water ,the water run then a release sound will appear and the water cut off. I swapped the cold hose with the hot hose same issue. I checked the cold water without connected to the faucet, the water is flow normally.
      1. calvin | Apr 21, 2020 07:23am | #3
        Integral sprayer or separate? Did you clean up the head screen etc?
        Was there a problem before the cartridge change?
        How about the shut off?
        Had a Grohe faucet and had to ream out/poke with a wire, the mixing area in the body where the mixing took place.
Drafting the 2027 IRC
  • The New Old Colonial
