Hi there.
We have an old (1926) stucco Bungalow and we are planning to re-model our kitchen. There are two windows in the kitchen that are about 6″ too low for the height of a conventional countertop.
I’d like to raise the window and/or install a shorter window that will raise the window sill enough to clear our new countertop.
I’m thinking about getting some Marvin Tilt Pac replacement window sashes for our house anyway, and I’m curious if I can rough in a new window sill for these two windows and just order the new tilt pacs 6″ or so shorter so they’ll fit into the new rough opening?
Are there any major flaws to this line of thinking? Is this a particularly bad idea or does it seem workable?
Thanks in advance.
No it doesn't seem like a bad idea. Shorter windows will be much easier than raising the existing window. the main difficulty will be re stuccoing the outside to match, but that shouldn't be to bad either.
Justus Koshiol
Running Pug Construction
Wouldn't those raised sills doll up beautifully with planter boxes to hide the stucco patch?
See, now there is a good Idea.
Justus Koshiol
Another option I did twice was a recessed plant area behind the counter. That is, assuming ample floor space for the extra counter depth. Worked out very well. Incorporated a knife rack there as well. Replacing the windows was not something my clients wanted to consider. Watering spills need to be expected.
you do have a couple of options
as suggested by others, leave the window, get a countertop with no back splash, and have a recessed plant area(great idea)
replace the windows to suit, dont forget the backsplash height if using a postform top, which is usually 4 1/2 inches above the cabinets, problem with this is exterior finish
moving the existing window up 6 inches will require cutting into the header(not a good idea)
caulking is not a piece of trim
If these windows are behind the counter top and would replace them with awning or casement for ease of opening and better view.
