Kohler DTV Digital Shower System?
DJRobJ | Posted in General Discussion on June 27, 2007 04:11am
We are installing this system in our new house with the Water Tile heads, jets, rain heads, ect…
I have not seen a functioning system, so I hope it is what we expect.  It certainly looks neat from what I’ve seen on Kohler’s site, ect…
Just wondered if anyone here has or has installed one of these systems and could offer me some feedback on it?  I’ve had a difficult time finding end users of this system since it’s relativly new.
Thanks, Rob.
Here’s a link if you don’t know what the DTV is. And no I am not plugging this system, just looking for opinions on it.
http://www.us.kohler.com/performanceshowers/dtv.jsp?section=2&nsection=2&nsubsection=3&category=11&nitem=cat11
  1. rez | Jun 30, 2007 05:55pm | #1
    Greetings DJ,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
     Before winter I built a chimney, and shingled the sides of my house, which were already impervious to rain, with imperfect and sappy shingles made of the first slice of the log, whose edges I was obliged to straighten with a plane.
    -Thoreau's Walden
  2. woodway | Jun 30, 2007 08:07pm | #2
    Don't know much about the DTV shower but in my experience, one item that often needs consideration 'PRIOR TO' install of the newer, multi head, shower systems is to be absolutely sure your HOT supply is at least 1/2" with good flow/pressure and COLD supply is 3/4", again with good flow, at a very minimum. All these "showroom" showers look great but practicality must be considered along with water supply to feed the whole system. If possible, put in 3/4" all the way around, not just the last 4 or 5 inches ahead of the shower.
    1. Notchman | Jul 01, 2007 01:56am | #3
      ....and plenty of water heater capacity.
      1. woodway | Jul 01, 2007 02:37am | #4
        Yes...and that too!
    2. DJRobJ | Jul 02, 2007 07:14pm | #5
      We are ok in that department.  This is new construction, and I have planned accordingly.  We have 1 1/4" supply from the meter to the house, 1" cold main throughout the house and to the 80 Gallon water Heater, and 3/4" Hot to the Master Shower.  The other day, my plumber finished the rough, and turned on the water to test the system.  MAN OH MAN, it is like a FIRE HOSE!!!  I was shocked, because our old house (previously on this same property) had NO pressure or volume at all.  Even the 1/2" hose bib all the way at the end of the line was gushing water out like a FIRE HOSE!!!  What a difference new plumbing has made.
      1. woodway | Jul 02, 2007 10:39pm | #6
        I can't count the number of people who've posted here complaining about insufficient water flow in their "new shower/bath remodel." It all comes down to planning. It's easy to install the proper size plumbing, or larger, ahead of time but try putting it in after all the tile is done and the job is finished. Not so easy, to say the least, at that point. Be glad you, or your contractor, planned ahead on this plumbing installation.
      2. smslaw | Jul 02, 2007 10:58pm | #7
        At "up to 21 gallons per minute" you had better have a major source of hot water.  80 gallons, even when mixed, isn't much for that sort of volume unless you have serious recovery capacity.
        1. reinvent | Jul 03, 2007 12:42am | #8
          One of these would help that problem if you have room for it 'down stream'http://gfxtechnology.com/contents.html#selection
        2. DJRobJ | Jul 03, 2007 12:56am | #9
          It flows up to 21 GPM with all 6 outlets turned on.  We'll never do that, no reason to.  We are installing a Propane Gas water heater with a fast recovery rate.  I don't expect it to be an issue.
Picture-Perfect Pergola
