Labor Cost Using LVL’s vs. Steel
| Posted in Construction Techniques on December 12, 2002 03:40am
 I need to replace an existing undersized wood beam in the middle of my garage with either LVL’s or steel.  The beam spans 20 feet and is set in pockets of the interior and exterior block walls.  I was told I could use either a W10x26 steel beam or four 14 inch LVL’s. The steel and LVL’s are very close in price. Being a one man crew confined to light duty, I need to sub this project out.  I was looking for someone to give me their opinion on which may be the most cost effective rout to take.  Thanks.  -Ed
  1. xMikeSmith | Dec 12, 2002 03:47am | #1
    you'll have more clearance with the steel.. will the 4" make any difference..
    the  steel will weigh about 520 lb... if you can get it delivered .. your crew can roll it and pinch it, and see / saw it into place and get it up faster than the 4 lvl's.. but .. if you have to plaster it... then the lvl's will be quicker because you can fasten directly to the lvl's... so.. depends
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  2. Piffin | Dec 12, 2002 03:54am | #2
    Assuming the beam is under the joists and not an insert,
    The steel is cheaper labor - you don't have thirty two holes to drill and fill
    "The first rule is to keep an untroubled spirit.
    The second is to look things in the face and know them for what they are."
    --Marcus Aurelius
