Lag Shield Hole Slightly Too Big…
| Posted in General Discussion on January 2, 2007 02:32am
If my hole in my concrete slab is just slightly too large for a snug lag shield fit, can I start my lag screw first and then tap both together in to the hole and still have it function properly? I’m just using them to keep a post on a short arbor from moving. Any ideas would be appreciated.
Thanks. JohnKu
  1. nikkiwood | Jan 02, 2007 02:43am | #1
    Packing some slivers of wood around the outside of the lead shield will usually do the trick. I will often use round toothpicks for this purpose.
    "It is what we learn after we think we know it all, that counts."
    John Wooden 1910-
    1. johnnyku | Jan 02, 2007 02:58am | #4
      Thanks. Toothpicks save the day more often than I'd like to admit! Kudos for the epoxy idea as well-if I had any laying around I'd give it a try.
      1. nikkiwood | Jan 02, 2007 04:19am | #7
        I didn't consider your application; but if this is going to be used outside, on a horizontal surface, where water would accumulate around the shield, then I agree with the others that it would be better to use something that won't rust -- like pieces of copper wire or galvanized finish nails that you have clipped off so they won't protrude.********************************************************
        John Wooden 1910-
  2. CAGIV | Jan 02, 2007 02:51am | #2
    either the slivers like Nikki suggested or epoxy would work
    Team Logo
    1. Piffin | Jan 02, 2007 02:57am | #3
      or glue or finish nails...
      no- I don't mean glue on nails;)
  3. joeh | Jan 02, 2007 03:04am | #5
    Cut nails, the fix all for lots of wrong holes.
    Joe H
  4. FastEddie | Jan 02, 2007 03:37am | #6
    Toothpicks will rot away.  small finish nails would work, or pieces of copper wire.
