Laminate floor backing question.
cmbb | Posted in General Discussion on September 17, 2005 10:40am
Gentlemen; I purchased some Kronotex laminate flooring . I am putting it in the livingroom/hall. I figure I will have it upstairs for a couple or three years and when I get the basement finished then the flooring will be pulled up and put in the bedroom downstairs. Or I will dislike it so much by then that I will burn it. At that time I will have figured out which “good” flooring to put in the living room/hall. I only have $600 in it, without the backing. So I wont be out too much with the experiment. It is one of Kronotex’s mid to upper model.
Anyway, the question is. What type of backing to use? Can I just use the thin foam or do I need a moisture barrier also?
It will go over 5/8 Advantech which has red rosin paper under it, and under that is 3/4″ spruce subfloor. I believe the rosin paper is a moisture barrier? Right?
I thought of going to Homedepot or similar and getting a pergo or other brand name backing. I know, it will void any waranty. But I dont have enough in it to pursue it anyway.
  1. rez | Sep 22, 2005 09:01pm | #1
    Greetings cmbb,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
    Perhaps it will catch someones attention that can help you with advice.
    Cheers
    r u a feckless dastard?
    1. cmbb | Sep 22, 2005 10:35pm | #2
      Rez;   Thanks! I have done a little searching on the net and found a few different underlayments that seemed decent. One being , Quiet Walk.
      Anybody have any suggestions on a decent internet flooring company, to purchase the underlayment?  I guess it does not have to be a flooring company. Just one that sells underlayment.
      1. rez | Sep 29, 2005 07:39pm | #3
        Well, let's try it one more time. If you don't receive the answers you need it may be worth your while to visit this flooring forum.
        http://www.floormasters.com/
