laminate floor with tiled wall
firedude | Posted in Construction Techniques on April 13, 2006 10:24am
planning on a laminate floor in an older kitchen – walls are tile to the floor (tile is in very good shape) with no way to attach molding/quarter round – considering using T-molding/transition strip but at $13 per 46″ piece, little expensive for going around the room (only about 12×12 room, but…..) – any alternatives from anyone?
also thinking about making my own “T-molding” but then the time might make the $13 “cheap”
thanks
  1. Stilletto | Apr 13, 2006 11:37pm | #1
    Can't you shoot the 1/4 round to the floor and not the wall?
    1. WayneL5 | Apr 14, 2006 12:20am | #2
      No, you can't.  Laminate floors need to float for expansion and you can't fasten them to the floor.
        JeffBuck | Apr 14, 2006 01:35am | #4
        Yes U can.
        1/2" or 5/8th 23G pin nails.
        18G even ...
        it'll float.
             Buck Construction
         Artistry In Carpentry
             Pittsburgh Pa
      BillHartmann | Apr 14, 2006 12:27am | #3
      No, but you could glue qtr round to the tile wall.
      1. firedude | Apr 14, 2006 01:51am | #5
        I thought about gluing the quarter-round to the wall but what adhesive to use and I really think it would look kind of "hack" against the tile - also, which trim to use with the tile? - wood against the tile might not look too good either - any suggestion from some tile guys with tile quarter round?
          RRooster | Apr 15, 2006 01:38am | #6
          What about some sort of tile base?
          Grunge on.  http://grungefm.com
