LARGE Cove Moulding!
DIYER | Posted in Construction Techniques on October 7, 2004 07:27am
Hey all,
I just signed on to a job that involves cove moulding to go between wall/ceiling joint and I’m trying to figure out how I’m going to be able to cut this Crown style moulding since it has a height and projection of 8.5″     – My miter saw can’t handle that size, I was thinking of upgrading, but I don’t know if any saw that is within reason can handle that.  Are my only options to build a miter box and cut by hand?  Please give me some advice if possible.
    Sphere | Oct 07, 2004 07:38pm | #1
    sliding compound saw and the right setting for a flat cut, or slap together a box and handsaw it..
  2. csnow | Oct 07, 2004 10:38pm | #2
    You could buy a manual compound miter saw.
    I have a Jorgenson.  Runs about $50, and can handle pretty tall stuff.  I think it could handle 8.5, though you would probably need to build a taller fence.  Taller fence is a helpful mod anyways.
    MarkH | Oct 07, 2004 11:04pm | #3
    You could make a homemade miterbox from plywood and use a handsaw to cut the molding. It was done a lot like that before power mitersaws were invented.
    1. dinothecarpenter | Oct 08, 2004 12:39am | #4
      If you put the molding flat to the floor (upside-down) what is the height?
      YCF Dino
      1. vanderpooch | Oct 08, 2004 02:00am | #5
        Gary Katz has an article about doing really big crown with a wooden miter box on his website. Might give you some good info if you can't cut it on the flat with your saw and don't want to upgrade.
        Here's a link: /TrimTechniques/cuttinghugecrown.htm
        -KITTechnique is proof of your seriousness. - Wallace Stevens
        1. Snort | Oct 08, 2004 04:17am | #6
          Don't take this the wrong way, but if you signed on to do a job with 8.5" crown, why can't you handle it? Dang, buy a big saw and change your handle...or sub it out to a pro<G> Don't worry, we can fix that later!
          1. FHB Editor
            JFink | Oct 11, 2004 04:50pm | #9
            I didn't sign onto the job yet Buck, but I probably will build a box similar to the one on Gary Katz's website - which I found shortly after asking this question here.  I didn't mean to sound like I had no idea how to do it, just wanted some tips on what people have done to make it easier, if they knew of a certain saw that could handle the size or whatever.  But I think building the miter box to fit the crown will be the best bet.  Thanks everybody.
          2. Snort | Oct 11, 2004 11:34pm | #10
            Hey, but you did change your name!<G>
            Is Katz's box for a handsaw? I started this stuff before power miter saws, it's no fun trying to trim just a scosh, LOL
            I've learned a lot of by taking on jobs I didn't have clue how to do<G>
            Good Luck Don't worry, we can fix that later!
          3. FHB Editor
            JFink | Oct 11, 2004 11:54pm | #11
            Haha, I always did like the feelings a name like DIYer invoked from Breaktimers!
            ..But anyway, yes Gary's box (or rather the box from his site - I think it was somebody else's writeup) is made for use with a handsaw and is specially designed so that you can accurately cut from one side and then move to the other side without screwing up your cut too badly.  It had a sort of guide fence to hold the saw at the right angle (right meaning correct of course !)
            -Justin
          4. Snort | Oct 12, 2004 12:04am | #12
            I think I saw that. But that wasn't big crown, that was huge crown! Might been Ed Williams' crew, GACC Dallas, he used to post here a lot.
            About the DIY thing, if a DYIer ever does find out how easy it really is to cut big crown with low tech tools, then we're going to have to move into stuff like dentistry...scary, huh?<G>
            Edited 10/11/2004 5:17 pm ET by bucksnort billy
  4. dinothecarpenter | Oct 08, 2004 05:21am | #7
    One way is to make a sled for your circular saw big enough so you can clamp it to the cove. Cut upside down (the molding ,not you ) and if you need to finish your cuts at the ends use a hand saw.
    YCF Dino
  5. gordsco | Oct 08, 2004 07:50am | #8
    Rent a slider for the day you are going to cut. I would install blocks every 2' for that size of moulding. Triple up the blocks at joints for extra gluing surface (if needed).
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
