Laser measuring tools
jonblakemore | Posted in Tools for Home Building on March 4, 2005 07:06am
I’ve noticed a proliferation of laser tapes recently. I’ve played with the Hilti but unfortunately the rep wouldn’t give me one. Measuring up a basement this afternoon got me thinking about these tools again.
There seem two be two main classes. Cheap and pro grade. Strait line, Stanley, and Calculated Industries have several models each in the $20-$60 range. Then you step up to the pro level tools and are spending $300 on sale.
This tool caught my eye and I’m wondering if it would be a happy medium. http://tinyurl.com/46g4l
The price is manageable but I would still want +/- 1/4″ over 50′ if I am going to take the plunge. Anyone have experience with this model? Anyone found a cheapie that can give somewhat accurate measurements?
Jon Blakemore
    BillHartmann | Mar 04, 2005 07:50am | #1
    Watch the spec's.
    "Accuracy 99.5% +/- 1/4" "
    That 0.5% is 3" at 50 ft.
    hammer1 | Mar 04, 2005 03:08pm | #2
    I found that these devices are not very accurate. You need a clear shot to an opposite wall, no pictures, plants, widows, etc. Shooting at reflective materials doesn't work and you need a clean, even surface to shoot towards. Try to find that in most homes. My inexpensive one was useless in hallways and closets, of course you need to keep spare batteries on hand. I returned mine.
  3. Shoeman | Mar 04, 2005 04:54pm | #3
    I have the Stanley IntelliMeasure 77-007 and have been happy with it
    May not be dead on accurate, but, it is certainly close enough for me to measure up a job quick for a bid.  Especially useful if bidding on a basement that is full of stuff.
    are these things actually using the laser to measure or is that just a pointing device and the actual measurement is made with ultrasonic sound waves?
    Edited 3/4/2005 10:33 am ET by Shoeman
      jonblakemore | Mar 05, 2005 12:56am | #5
      Shoeman,What kind of accuracy do you achieve?
      Jon Blakemore
      1. Shoeman | Mar 05, 2005 02:16am | #6
        I never checked closely.
        When I saw your post, I went around the house and shot several things between 3 and 24' and checked with a tape.
        Every shot was withing 1/2" as this model rounds to the nearest inch.
        Like I say, it has worked well for quickly measuring rooms for bids and materials lists
        Think I paid like $35 for it a couple years ago.
        1. mikerooney | Mar 05, 2005 04:58am | #7
          I learned to "Step off with a full thirty" in the U.S. Army.
          Two steps = 5'.
           6 16 17 97 99
  4. timkline | Mar 04, 2005 06:25pm | #4
    I use the PLS1 every day.
    http://www.amazon.com/exec/obidos/tg/detail/-/B00004TR4O/qid=1109949781/sr=1-1/ref=sr_1_1_etk-tools/102-4881096-0884946?v=glance&s=hi&n=228013
    Pricey, yes, but awesome.  I have one of the Sonin sonar units.  I don't have the patience for the thing anymore. Especially since anything that gets in the way causes interference.
    If you have used the Hilti units, then you know the difference. Lasers are the nuts.
    carpenter in transition
  5. des | Mar 05, 2005 07:12am | #8
    I have the higher priced Hilti that does triangulation measurements. It is highly accurate. I have used it to measure joists that needed to be dropped in between flush headers. I have used it to measure studs when stick building walls in basements or for temporary supports. It is fantastic for baseboard and crown mouldings.
    I know that I am going to find a lot more uses for it. The only drawback on my model (don't have the # handy) is it is a little bulky. But i understand that they have come out with a more recent model that is a little slimmer with possibly a few less features.
    If you can afford it get a good one. I knew it was a good investment the first time I used it.
  6. danski0224 | Mar 05, 2005 03:23pm | #9
    I have the Pacific Laser PLS1. Yes, it was expensive, but it has saved me a lot of time and steps on a ladder. Claimed accuracy is within +/- 1/8 inch at 300 feet.
    It seems to be correct, but that is for distances checked with a 30' tape in one shot. The resolution is awesome, I can get a distance off the small side of a 2x at 50 feet.
    I suppose if you want the tool for basic, rough measurements, then get a cheap one.
    If the numbers that the tool gives need to be correct, then spend the money.
    Either way, the laser pointer feature is a big plus.
      jonblakemore | Mar 05, 2005 04:47pm | #10
      I'm wondering how many who use the more accurate models use them for estimating and/or work in the field.I have thought about a Hilti or PLS1 for measuring trim, duplicating existing rafters, etc. I know the speed would be great but I would be more hesitant to take a $350 tool out in the rain with me.Still, if it's well made the time savings could easily make up for it's price even if it does wear out faster than if used just for office work.
      Jon Blakemore
Versatile Vise
