i use a few lasers for leveling and squaring and always find myself squinting at the bright spot trying to estimate the center. of course as the distance increaes, the spot gets bigger. anything out there to improve on this? I went back to an nice, self-leveling Nikon optical transit for touchy work.
Newer pressure treatments don't offer the same rot and decay resistance. Follow these simple strategies to give outdoor lumber its best chance of survival.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
When I'm leveling the transit by centering the bubbles in the vials, that spot is moving up & down 2 feet for every half a hair I'm off.
How big the spot is & how far off my guess at where the center is can't be nearly as critical as how accurate my bubble is. I don't think I could lose more than 1/8" in that spot, but them bubbles & my bi-focals are another story? Joe H
*Water in a long tube is much more accurate. The zircon unit with the electronic unit is great. Cheap too.
*Joe- The bubble setup and scale have to be spot-on. Other than economy, I've never thought that a laser level should be anything LESS than self-leveling. Otherwise I, too, prefer an optical builder's level...........Nigel- I agree with you about the water level for accuracy, but in my experience it is too much time and hassel to use. Frankly, for most residential work, I think that the Robolazer for $400 is THE best thing on the market.
*j.. My Empire laser shoots a dot with concentric rings. You can fix it on a wall and easily mark the center of it.
*Ken I am thinking of getting the Robo Laser. The price I'm seeing is around $250. Is it the same Model RB01001 Any problems or things you really like about it.
*Dale- Don't own it but used it a lot at my last employer. Rotates (but is not a 'rotating' level ie. does not use a sensor), meaning you can rotate it to the stationary position you need it at. Self-levels with one complete rotation. Has a remote control for all operations and so is perfect for one man usage. Tripod mountable, but you CAN set it up anywhere stable and close to level, altho if you set it up on, say, a deck surface, it will bounce when someone walks by. $250 is about the going price. -Ken
