Latex Paint Lap Marks
EricS | Posted in General Discussion on November 2, 2004 06:40am
I was putting the second coat on some fiber cement yesterday (BM 100% acrylic latex) and I could not avoid lap marks.  The paint/brush was dragging was I started to smooth out what I had initially applied.  Very little, if any problems with first coat with essentially same temperature conditions.
Can I sand these lap marks out and reapply a thin coat with floetrol?
I now almost feel as though I should be using floetrol
  1. BillBrennen | Nov 02, 2004 08:43am | #1
    Eric,
    You answered your own question. Go Floetrol!
    Bill
  2. andybuildz | Nov 02, 2004 03:22pm | #2
    I use Flotrol on just about every application.
    It actually doesnt cost more money because it adds to the volumn of paint.
     The best things in life are nearest: Breath in your nostrils, light in your eyes, flowers at your feet, duties at your hand, the path of right just before you. Then do not grasp at the stars, but do life's plain, common work as it comes, certain that daily duties and daily bread are the sweetest things in life.
    —Robert Louis Stevenson
  3. TrimButcher | Nov 02, 2004 05:07pm | #3
    Eric, what kind of paint was that? What's the temperature, and are you painting in direct sunlight?  Sounds like you're overworking the paint.
    Before Floetrol, I'd like to understand why you're getting lap marks.
    Regards,
    Tim Ruttan
    1. EricS | Nov 02, 2004 11:00pm | #4
      Well, I solved my own problem and it was a "stupid" mistake that I hope to not ever repeat.
      I was using a very good paint, a new Purdy brush and going from right to left because I'm left handed.  Unfortunately, even though it was only about 70-75 degrees, the sun had heated up the siding such that it was cooking the paint almost immediately.
      Now I'm about to find out how easy it is to lightly sand out lap marks and lightly recoat.
      Thanks for everyone's comments.
      1. DanH | Nov 03, 2004 01:26am | #5
        When we repainted last I tried to avoid painting hot siding, but once or twice it couldn't be avoided. Was rolling with a 6" roller, then backbrushing. I found that keeping a can of water around for the brush was quite helpful -- just "tip off" the brush in the water every few strokes and the paint didn't drag or leave brush marks.
Versatile Vise
