Hi,
I’ve been scratching my head for some time about this so I thought I’d run it by you guys. I have 2 car garage that has a small utility room that I wanted to make into a laundry room. The problem is that the garage main drain is right at the opposite corner of the garage. Is there a way that I can install a washer/dryer in the utility room? I have a second idea of just building a small exterior enclosure near the drain that could house the washer dryer. Not sure if that would be allowed by code but it would make things easier. All sugestions appreciated.
Mike
Tips for protecting your personal information when using Wi-Fi-connected devices.
What about a pump and check valve to push it up and across the ceiling, into the main?
since washer machine is classified as grey water, here you can run it out on the ground
That'll be great. I'll look into that.
Mike
