What is the saafest, most efficient, cheapest way to build up a masonry chimney in the center of a 10:12 sloped roof right at the ridge? The house is two stories plus a full attic and the chimney is approximately 4′ by 6′ with brick veneer. Any advise would be appreciated.
![](https://images.finehomebuilding.com/app/uploads/2024/07/16155452/01232572-fireblocking-thumb-16x9.jpg)
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
kyle.. this is a trick question,, huh?
wat am i missin?
*Kyle, Start at the footing when you get about three feet above the roof ...stop. Or you could always hire a mason.
*I suspect that what you want to know is how to hang brick veneer off frame construction when it doesn't extend to the foundation wall? As in shelf angles, etc.?
What is the saafest, most efficient, cheapest way to build up a masonry chimney in the center of a 10:12 sloped roof right at the ridge? The house is two stories plus a full attic and the chimney is approximately 4' by 6' with brick veneer. Any advise would be appreciated.
