Leak shutoff valve???
larryb | Posted in General Discussion on March 28, 2009 02:44am
     Four vacation rentals on one shared well.  Large holding tank With constant pressure pump.  Running toilet shuts down well..If I’m reading this scenario correctly.   No water in holding tank.  Reset well, water on.
     My question..Can I get a water leak(programmable?) shut off for each house,so that the whole system doesn’t go down.
thanks   Larry B
   love covers a multitude of sins   God
  1. Ozlander | Mar 28, 2009 04:06am | #1
    If one running toilet runs the well out of water, then you need three more wells.
    Ozlander
    1. Shoemaker1 | Mar 28, 2009 05:42pm | #2
      Have you had a "draw down Test" done on your well? maybe the well is overtaxed? is there a back flow check valve that is not working?
      Probably easier to put a master shut off on each unit and shut off system between clients and fix the leaky toilet.
      1. larryb | Mar 28, 2009 10:34pm | #3
         Thank you for the info. Wil do a "Draw down test"
        Larry B
  2. dude | Mar 30, 2009 11:24am | #4
    putting a shut off valve on a toilet is called Plumbing I01 , learned very early in life & also turn valve every 6 months to make sure it isent frozen up , Plumbing 102
    1. larryb | Mar 30, 2009 04:33pm | #5
      thanks dude,
           I'm looking for an auto shutoff valve that actuates when there is a leak or an unusual amount of water used in the whole house. For instance, frozen,burst pipes or a running camode.
      Larry b
      1. Billy | Mar 30, 2009 05:45pm | #6
        Check out http://www.watercop.com
        I have one in my older home and it has easily paid for itself.  Also, it lets you know when there is a slow leak you might not otherwise find quickly, such as under a sink.  The downside is you have to install sensors in each bathroom, by the washer, under the kitchen sink, etc.
        Billy
        1. dude | Mar 30, 2009 08:41pm | #7
          you can get a pressure control that shuts off the pump when it hits 5 psi so as to not pump the well dry
          it has a manual reset lever on the side of the switch
          they cost only a couple of dollars more than a regular one
          for a pressure gauge i use stainless oil filled which we buy here for about $10 US
          after getting half drowned once in the winter i never use anything else & have never needed to replace one in the last 20 years
      2. JTC1 | Mar 30, 2009 09:54pm | #8
        ....an auto shutoff valve that actuates when there is a leak or an unusual amount of water used in the whole house. For instance, frozen,burst pipes or a running camode.
        I don't think you will find such an animal, primarily because of the flow rate involved with a leaking commode - it's not really a high flow rate. Yes it obviously adds up over time, but it is not a large flow.
        If you could find an auto shutoff valve for the whole house which would actuate upon the toilet fill flow ------ the toilet would become unusable - when the toilet was flushed - the valve would shut off the flow!
        Most other water consuming points would also be unusble because that pesky valve would be shutting down the flow.
        Have I missed something?
        JimNever underestimate the value of a sharp pencil or good light.
        1. larryb | Mar 31, 2009 02:08am | #9
          Thanks Jim. I am just trying to tap this large knowledge base.
          Your reply was very helpful.  The oil filled gauge is a great idea as the regular ones freeze and are inop.
          Larry B
  3. iluvgear | Mar 31, 2009 02:18am | #10
    Replace the valve in the leaky toilet with a Fluidmaster Leak Sentry.  If the tank has a slow leak into the bowl, this valve will not allow the tank to refill.  This is cheap and easy and will give you breathing room to fix things correctly.
    1. larryb | Mar 31, 2009 05:23am | #11
      Thanks gear,
          This might do the trick for leaking toilets. I'll try it.
           Larry B
