We’ve had a lot of wind driven rain (raining sideways) this year and I’ve got two windows that leak after these hard rains. The water comes in from the top of the window frame. The building is brick and the perimeter of the window frame is well caulked. I’m guessing the windows weren’t flashed properly and there’s nothing I can do about it. Any ideas?
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
karl
Without pictures or more information it will be tought to get good answers.
Caulk may look good but still leak.
My guess is that the brick is leaking somewhere above the windows.
But my latest experience with a brick building was a 1930s brick building and a flat roof. The leaking came from cracked mortor joints and a poorly sealed parapet wall on the roof.
I am going to go out on a limb here but if it is leaking between the window and the extention jamb then there is a good possiblity that it is leaking above the window.
I hope this helps.
Rich
Lack of thru flashing and weeps in the brick are probably at fault. But w/out a picture we're all guessing as much as anything.
"If Brains was lard, you couldn't grease much of a pan"
Jed Clampitt
Put up some pics.
I'd venture to say it's probably the flashing
or missing mortar on the bricks.
marant
I would venture to say that ALL doesn't have any pics of the problem.
Maybe Karl does. LOL
Rich
Yeah, I doubt ALL has any pics :)
marant
I'm glad you have a sense of humor.
Rich
Actually, with wind-driven rain flashing can actually be the problem. It's possible to have rain driven under the flashing above the window and from there into the structure.
But as the others have said, it's hard to say without a close examination. (And even then, water can do some strange things.)
