bayviewboom
| Posted in Construction Techniques on
Hello
I want to cast a polymer, epoxy, or resin. It must be crack-resistant when compressed. Prefer a clay or putty.
I tried JB SteelStik, and it cracked under compression.
Don’t need bonding.
Fancy expensive products are not an option.
Fyi, this is related to a youth engineering program i started, for at-risk teenagers.
bayviewboom.org
thx!
You don't have to sacrifice historical elements of a house in the name of energy efficiency.
RTV
Butyl caulk
Polysulfide
etc..
Or, even better - soak old scrap nylon (old spatula, old kitchen plastic, etc) in water for a day, it will absorb wter enough to make it have a high dissipation factor at 25 GHz.
Place in melamine or glass bowl in microwave until pourable, and cast.
Let cool.
# 3
cut up washed hdpe poly milk or juice cartons, place pieces into a metal Teflon coated bowl.
Place in oven at 500F, remove and pour when melted.
