LEAVE OR REMOVE GABLE VENTS
workdog2 | Posted in General Discussion on July 30, 2008 09:05am
Since I’m residing & my home has both gable & soffit with ridge venting I figure now would be the time to remove the gable vents. I have heard in the past they can cause problem in the air flow with the soffit & ridge venting & even suck in snow. I’v had them with the soffit venting for over 10 years with know problems but why waste the cash for new to match the new siding??????????????
    rjw | Jul 30, 2008 09:15pm | #1
    I agree in principle with the "remove 'em" crowd, but in my inspections in NW Ohio I've never seen any evidence of problems actually occurring.
    Remember Mary Dyer, a Christian Martyr (Thank you, Puritans)
    http://en.wikipedia.org/wiki/Mary_Dyer
    May your whole life become a response to the truth that you've always been loved, you are loved and you always will be loved" Rob Bell, Nooma, "Bullhorn"
  2. DanH | Jul 30, 2008 09:18pm | #2
    You don't have to remove them -- you can just block them off from the inside with cardboard or whatever. The seal doesn't have to be perfect.
    It is an ironic habit of human beings to run faster when we have lost our way. --Rollo May
    1. workdog2 | Jul 31, 2008 07:19am | #14
      Since I'm residing I'll just remove & re-sheath the opening no since leaving it no future use for it.
      1. workdog2 | Jul 31, 2008 07:23am | #15
        THANKS TO ALL FOR THE INFORMATION.
  3. john7g | Jul 30, 2008 10:32pm | #3
    no need for the gable vents.  Now's a good time to ensure you have enough soffit vent so they aren't choking the flow of the ridge.
    1. qtsam2 | Jul 31, 2008 01:16am | #4
      speaking on nw ohio i see many homes with gable vents but no soffit or ridge vents.
      should those be covered up as well?
      1. frammer52 | Jul 31, 2008 01:21am | #5
        Only if the have ridge vents.
      2. john7g | Jul 31, 2008 01:55am | #6
        like OMF (Old Man Frammer) says.
        The gable vents will short circuit the desired convection current/air flow of the ridge/soffit vents.   For soffit vents I prefer the continous louvered piece the whole length of the eave.
        1. frammer52 | Jul 31, 2008 01:58am | #7
          Hey I resemble that!
          1. john7g | Jul 31, 2008 02:23am | #8
            OMF could mean something else.  :)
            edit to add smiley
            Edited 7/30/2008 7:26 pm ET by john7g
          2. frammer52 | Jul 31, 2008 02:41am | #9
            I thought the original was fine, thank you.
        2. qtsam2 | Jul 31, 2008 05:35am | #10
          i understand what you are saying about it disrupting ridge/soffit circulation but my question is if there is no other venting except gable vents. as i said, this is predominant in alot of older homes i see here.
          1. JeffinPA | Jul 31, 2008 05:40am | #12
            You need the ventilation so if it only has gable vents, then you want to keep them just the way they are unless you change the method of attic ventilation.
          2. john7g | Jul 31, 2008 01:21pm | #16
            keep the gables if there is no other venting
    2. workdog2 | Jul 31, 2008 06:59am | #13
      Solid perforation across all soffits lots of air flow to ridge vent
  4. JeffinPA | Jul 31, 2008 05:38am | #11
    Cover them up.
    I have seen nightmares.
    you want good air flow from soffit to ridge and the gable vents can cause dead spots in the air flow depending on wind, home orientation, etc.
