ledger board on concrete foundation wall
sawdust58 | Posted in Construction Techniques on February 12, 2008 03:35am
I just finished replacing a deck with a poured foundation with a sun room on it, now I have to tie the other existing deck to the foundation, that means a ledger board on concrete with no siding above, how do you flash such a beast?
  1. IamtheWalrus | Feb 12, 2008 04:19am | #1
    If your truly not penetrating the siding it sounds like you only have to
    use spacers 'tween the ledger and the foundation.Any water that gets
    behind it will drain away.There's also air space to help it dry.Theres a
    company that makes little disks designed for this that I've seen
    advertised in FHB.But you could probably use trex or something at the
    lag spots instead.In the Mike Maines article in the current issue he
    talks about spacing doubled up joists as well for the same reason.
  2. Riversong | Feb 12, 2008 04:44am | #2
    You can lag a PT ledger directly to the concrete, or if you're worried about moisture wicking into the ledger apply it over a strip of bituthane.  Use Z-flashing on the top edge of the ledger and seal it with urethane caulk to the foundation, or just use a bead of PT-rated adhesive (such as PL500) between the top of the ledger and the concrete during installation.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
