Level on the level
BamaTom | Posted in Tools for Home Building on October 29, 2003 06:10am
Could someone experienced in doing so please enlighten me on how to level out a dumpy level of the type that has three (not 4) leveling screws under the instrument.  My only experience has been with the 4 screw type, and, while I can fumble around and get the 3-screw instrument leveled, I know there has to be a standardized, streamlined way to get it done.  The owners manual is no help at all.  Thanks in advance for all advice.
    SamT | Oct 29, 2003 07:56pm | #1
    Use a calibrated Mark-I eyeball or torpedo level to set the tripod table close to level. . . Set all adjusting screws to midpoint of travel.
    Set the sight tube parallel to two screws and adjust the third. Rotate the tube 120 degrees and repeat. Do the last screw the same. . . Repeat the whole procedure 2 or 3 times to fine tune. . . Takes about 90 seconds.
    SamT
    "You will do me the justice to remember that I have always strenuously supported the right of every man to his opinion, however different that opinion may be to mine. He who denies to another this right, makes a slave of himself to his present opinion, because he precludes himself the right of changing it."   Thomas Paine
Big Doors Have Big Challenges
Engineered materials and vacuum-press laminations prevent warping and keep a tall, flush-panel door from being excessively heavy.
