leveling a sill under a patio door
user-77150 | Posted in Construction Techniques on December 10, 2006 12:40pm
I have an 8 foot wide sliding door. the sill is aprox. 3/8 out of level over the length of it. How would you approach this job? A few shims and a lot of caulk?
  1. dovetail97128 | Dec 10, 2006 12:52am | #1
    What is the sub-surface you are setting it on?
    1. user-77150 | Dec 10, 2006 01:11am | #2
      plywood on 2x joists
      1. dovetail97128 | Dec 10, 2006 05:29am | #5
        Lots of possibilities. Just a few..
        1) Rip tapered shims off the edge of any 2x stock that is 8' long using a "skilsaw" (I like 2x6 , easier to control the saw on the wider stock ) Glue and pin or finish nail the shims down.
        2) Set up an outside form that is level and snap a line that is level along an inside form , use "bondo" and fill the "form" to level. You can use floor patch for this but I prefer "bondo" type body fillers myself .
        3)Commit heresy and set the door out of level and rack the frame to plumb, use the wheel adjusters to make the door adjustments for the out of level.
        1. user-77150 | Dec 13, 2006 10:18pm | #6
          Thanks for all the ideas. I'm going to go with a solid tapered piece of wood and caulk.
          1. dovetail97128 | Dec 13, 2006 10:34pm | #7
            That will work, pretty easy to do .Just make sure to glue it to the subfloor.
    Sphere | Dec 10, 2006 03:33am | #3
    Band sawn long taperd wedge.
    I have irriatable Vowel syndrome.
  3. IdahoDon | Dec 10, 2006 05:08am | #4
    Are you saying the threshold sits on the floor, but because the floor is uneven it won't sit level without a gap between floor and threshold?
    What's the finished floor going to be?  If it hasn't been installed yet you should try to determine how the floor guy is going to deal with the out of level subfloor.  Does the client know his floor is out of whack that much?
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
