Leveling joists and subfloor fasteners
danf26 | Posted in Construction Techniques on June 28, 2011 06:34am
Hi all,
Im installing a floor for the first time, and Im about to ask some questions that Im sure have been asked before on this site. If youre able to bear with me here, thank you.
Right now I have girders installed over piers, and despite shimming, my water level tells me that there are some serious discrepancies in level in some places 3/4″). So, what I will do is find the high spots, put in those joists first, making sure they’re level, then running a string across them. I will then shim up all other joists to their height (which will be good as the joists are rough sawn, and probably have some discrepancies among themselves). Anybody have more efficient ideas to get my floor level?
Subfloor will be rough sawn 1×8 hemlock. They will be laid down over housewrap to help reduce drafts. For the exterior spaca (deck) I will use exterior deck screws, but what fasteners should I use to secure the interior subfloor to the joists? And at what spacing? A friend recommended 1 3/4″ bright ring shank underlayment nails. Good enough?
Thanks in advance to anyone who responds,
Dan
  1. oldhand | Jun 28, 2011 09:15pm | #1
    very rough floor framing..........
    There are lots of ways to flatten a funky floor frame, your plan may work. Hopefully this rough sawn isn't green...
    I can't say surely without being there to see more variables but my first thought would be to install the rims and shim/trim to a string line between them.
    A lot of work.
    I would install the  1" subfloor with 2.5" nails, preferably ring or screw shank then cover with tarpaper before the finish floor.
    1. danf26 | Jun 29, 2011 09:32am | #4
      Rough sawn is green. Or fairly so at least. Milled about 6 weeks ago, from hemlock logs that have been down for around 4 years. Still pretty green though. Shrinkage?
      Why use tarpaper if Im already using housewrap between the joists and subfloor?
      1. oldhand | Jun 29, 2011 07:40pm | #6
        wet may not mean green....
        If the logs have been dead for 4 years they can't be "green", as in full of sap but they can still have a high moisture content.
        Green lumber is still somewhat plastic and has a strong tendency to sag under it's own weight till dry when installed on edge as in a joist. Like  maybe a 1/2" crown down in 12 feet.  Real high moisture content maybe not so bad for that but both will shrink in width, a bit even in length. Not the end of the world though in any event.
        If your subfloor is also rough 1" boards wet enough to shrink you can expect some rodent sized crawl ways to possibly form between the boards over time if the boards are very wide. Again not the end of the world.
        I would not personally install the house wrap between the joists and subfloor at all. I would use tarpaper on top the subfloor and save the housewrap for the walls. Don't ask me for the science on that, I think it's because momma said "because I said to, that's why".
  2. calvin | Jun 28, 2011 11:11pm | #2
    Subfloor screws and glue.
    Level how you wish but shim solid, don't just stuff in cedar shims.
    Glue the subfloor to the joists and use subfloor screws of the proper length and a stand up screw gun.
    Nails are quicker and with ringshank, you should have no problem.  Personally, I like screws.  Both beat the heck out of air driven 8's.
    1. danf26 | Jun 29, 2011 09:30am | #3
      Why shim solid and not cedar shims? What material classifies as solid?
      Glue the subfloor with what? What might that product be called, and what is its function if nails/screws will be used?
      1. calvin | Jun 29, 2011 10:12am | #5
        Well, cedar shims can crush.  If you stack 3/4" of them to fill a space, why not use a chunk of 3/4 plywood.  For an ince, 2 pcs of 1/2...........I carry recycled blocks of ply and use them when setting cabinets etc. as cedar shims split, slip out etc when you stack them high.  They have a use-mainly in setting jambs or fine tuning because of the wedge shape.  Because they're called shims doesn't mean you use them exclusively.  Blocks of solid 3/4 or 1-1/2 work also.  I'm warry of using 3/4 pine as it is soft, sooner use plywood.
        If shimming a beam-steel shims are the only thing allowed here.  Again, because of the weight, you don't want it to crush.  Joists, wood shims are  fine-solid shims are better than fine.
        Subfloor glue of course.  I'd use PL Premium urethane adhesive-in both small and large tubes.  The function is better holding power, fills voids and bridges gaps and in the case of PL Premium-it'll hold for near ever.
