leveling stem walls
pell | Posted in Construction Techniques on May 27, 2009 04:32am
I am about to frame on a stemm wall that is 1 inch out of level ,and i generally shim next to anchor bolts grind etc.to get pretty close.I wonder if you can use structural grout to pour on the wall top with 1/4 ply attached to the sides and screed it flat where it needs to be taken care of.most walls are relatively short (pretty cut up stem).I just dont want to use any wood in there to shim as there are alot of beams etc. and I dont want any drywall cracking.Is there a better way to do this.Is this just stupid if the grout comes to a thin edge at some points Thanks Pell The walls im usually on are not this bad but hey I dont know how low this low bid s… goes.
  1. Framer | May 27, 2009 05:04am | #1
    Set the two outside corners nailed/plumb and level and string a chalkline and cuts the studs to the line. No plywood/grout/shims or anything else.
    Joe Carola
    Timuhler | May 27, 2009 05:22am | #2
    If you are framing walls, then follow Joe's advice.  I've got pictures here to show how its done http://picasaweb.google.com/TimothyUhler/Lot36Muirkirk
    If you are framing a floor on top of the stemwalls, then you can use Quikrete.  I'd just clamp material to both sides of the foundation level with your string, and then pour the Quikrete and you are good to go.
    http://www.quikrete.com/ProductLines/FastSetNonShrinkGrout.asp
    http://www.pioneerbuildersonline.com
    From Lot 30 Muirkirk
  3. brownbagg | May 27, 2009 05:40am | #3
    yes, that high strength non shrink grout works good for this, if you want you can add some steel shims for the wall, like we do with red iron, but its not needed.
  4. jimAKAblue | May 27, 2009 01:57pm | #4
    I've "fixed" many like this using steel shims under each beam (and stud/joist).
  5. pell | May 28, 2009 04:22am | #5
    Thank you all for your help.I did not make clear that it is a floor framed on the walls. Tim very nice work photos with clear info on execution,nice touch.Thanks again Pell
