Lexann or See Through Floor
geoffharris | Posted in Construction Techniques on June 4, 2007 08:29am
Does anybody have any experience with a see through floor?  Would it just be lexann/plexiglass?  Or is there a special type of material that would hold weight a little better.  I’m thinking the floor jopist have to be at least 12″ o.c. to support the weight but I don’t even that would be enough to support people and/or furniture.  It doesn’t have to be approved by an inspector because it’s going to be in a vacation house, but at the same time I would never build anything where I am not 100% sure of the quality of the floor breaking or cracking.  I’m thinking there must be some special manufacturer where they make it thicker than lexann.  Any thoughts?  Any ideas?
  1. frenchy | Jun 04, 2007 08:38am | #1
    Geoffharris,
     The public libray in Winona Minnesota has a glass floor,  It's very cool but I don't remember the details. Off the top of my head I think the floor was based on 3 foot centers.
    AaronRosenthal | Jun 04, 2007 08:41am | #2
    Wow. What a plan!
    REALLY curious....
    A vacation home with a difference.
    I don't believe you. I think you are putting us on. Tell the truth! It's for a college frat house, right? LOL!
    Quality repairs for your home.
    AaronR Construction
    Vancouver, Canada
    1. geoffharris | Jun 04, 2007 08:49am | #3
      No...not putting you on....The homeowner has a large 10 foot window on the second floor and the second floor is half framed and lets a lot of natural sunlight onto the first floor.   So if he frames the second floor off he will lose all of that light for the first floor.
      Any idea of the name of the material that was used in that library?
        BillHartmann | Jun 05, 2007 04:13pm | #21
        "No...not putting you on....The homeowner has a large 10 foot window on the second floor and the second floor is half framed and lets a lot of natural sunlight onto the first floor. So if he frames the second floor off he will lose all of that light for the first floor.Any idea of the name of the material that was used in that library?"IIRC there was an article in FHB a few years ago for exactly that same situation..
    2. Ragnar17 | Jun 04, 2007 10:25pm | #8
      Yeah, it sounds like some sort of one-way mirror type of thing!
    3. Piffin | Jun 05, 2007 01:00am | #12
      You been on them up-skirt videos again?;)
        AaronRosenthal | Jun 05, 2007 07:48am | #18
        There's enough peep-show stuff goin' on here, thanks.Quality repairs for your home.
        AaronR ConstructionVancouver, Canada
  3. exfitter | Jun 04, 2007 09:59am | #4
    Try this site I looked into this once but client changed their mind
    http://www.ibpglassblock.com
  4. Danno | Jun 04, 2007 01:57pm | #5
    Don't know about Lexan, but Plexiglass will scratch pretty easily and I would think it would soon be so scuffed as to no longer be transparent. You could "laminate" Plexiglass--put a layer of real (tempered?--don't know what is used for floors--I know they have glass floors in the rotunda of Michigan's capitol) glass on top of the Plexiglass to protect the Plexiglass.
  5. DanH | Jun 04, 2007 09:45pm | #6
    Yeah, you want polycarbonate (Lexan, I believe) not acrylic (Plexiglass). Much stronger and more scratch resistant.
    But still the stuff will be apt to scratch under regular use, so one wonders if a textured material should be used, so that the wear will be concentrated on the high spots, leaving the bulk of the material clear. (Don't know if a suitable textured is readily available, though.)
    In any event, either polycarbonate or glass. Acrylic is too brittle and scratch-prone, while polycarbonate is (quite literally) bullet-proof if thick enough, and is plenty strong. Do be warned, however, that it's very difficult to "machine". You'll likely have to make special arrangements for cutting the stuff.
    Somewhere on the web there are likely numbers for the strength of polycarbonate. In fact, here are the numbers for standard Lexan:
    MECHANICAL PROPERTIES:
    Specific gravity (ASTM D 792) : 1.20
    Tensile strength, Ultimate (ASTM D 638) : 9,000 p.s.i.
    Elongation at break (ASTM D 638) : 130%
    Tensile modulus (ASTM D 638) : 3.1x10~5 p.s.i.
    Rockwell hardness (ASTM D 785) : R118
    Impact strength (73° F) (ASTM D 256) (notched) : 17.0 ft-lb/inch
    Flexural strength (ASTM D 790) : 14,200 p.s.i.
    Flexural modulus (ASTM D 790) : 3.4x 10~5 p.s.i.
    Wear factor against steel 40 psi 50fpm : 2500x10~10
    Coefficient of friction 40psi 50fpm : 0.38 Dynamic
    I'm guessing someone out there can take the above and give you the equivalent of a 1-1/4" plywood floor, say.
    The clear material's readily available as thick as 2", typically in 49x97" sheets. If you don't need "window grade" you can get it up to 4". I would guess, however, that an inch or an inch and a half would be plenty.
    Price-wise, though, you're probably looking at some coin.
  6. jerseyjeff | Jun 04, 2007 09:59pm | #7
    They did this in the grand canyon,  and they have one like it at rockefeller center in NYC....  thick glass...
    jeff
    jmmmm
    1. DanH | Jun 04, 2007 10:33pm | #9
      Perforated iron/steel floors used to be fairly common in old (ca 1900) office buildings and libraries, to allow light to get through from a central skylight to the lower floors. I gather that gentlemen were on their honor to not look up when there was a lady above (or, God forbid, a Scotsman).
  7. User avater
    BarryE | Jun 04, 2007 10:40pm | #10
    Here's the glass they put in our downtown library recently. Not sure of the details, might try a google
    Barry E-Remodeler
    Edited 6/4/2007 3:43 pm by BarryE
  8. sapwood | Jun 05, 2007 12:24am | #11
    Glass block would let through light while still obscuring people's private parts.
  9. reinvent | Jun 05, 2007 02:05am | #13
    As some have said, you gota use glass NOT plastic of any kind. The thicker the glass the bigger the span. The two pictures I have included are at the CN Tower in Toronto.
    Also read this: http://www.pilkington.com/europe/uk+and+ireland/english/building+products/for+trade+customers/faqs.htm#faq5
    And scroll down to Q #5
    BTW it is best not to have the glass span across any joist. You should frame the opening like you would a window in a wall. Otherwise the glass will squeak and scratch.
    Edited 6/4/2007 7:08 pm ET by reinvent
    1. DanH | Jun 05, 2007 03:36am | #15
      There's no reason why you can't use plastic. It's all a matter of working out the numbers. The only problem with plastic, as I said, is that it's more apt to get scratched, but it doesn't sound like this duty would subject it to a lot of wear.
  10. ted | Jun 05, 2007 03:08am | #14
    The place I work at (Miami University) has a glass floor in one of the buildings. It's something like 1 1/2" thick glass plank. I think they are about 8 or 10 inches wide and 6 feet or so long. the planks sit in angle irons which bear on a beam system.
    Bear in mind the floor gets a lot of traffic and it is not transparent at all (never was) which is probably a good thing for those in dresses. But the scratches subtley cut down on the light infiltration over the years. And they recently resurfaced the floor which brought the light level below way back up.
    I would think a plastic floor would be a little slick in the beginning. And as it started to wear the scratches would concentrate on the traffic patterns of the space causing an uneve n wear appearance over the floor. After awhile all the dirt and crud would lodge in the scratches and be a maintenance problem and be a pain to clean.
  11. barrmo4321 | Jun 05, 2007 03:54am | #16
    I work with 3/4 " acrylic all the time, and while it is very strong it scratches whenever a piece of dust is moved across it. I would never put it on the floor. It is plastic , it will scratch and when the scratches fill with dirt it will be gross and impossible to clean. Stick with glass. Barmo
    1. DanH | Jun 05, 2007 06:22am | #17
      Yes, but polycarbonate is an entirely different critter. Something like 4x stronger, and 10x more scratch and shatter resistant.
        MarkH | Jun 05, 2007 01:52pm | #19
        Where do you find the polycarbonate is more scratch resistant?  It's been my opinion that it scratches easier.  The thing about polycarbonate is that it is not brittle.  You can bend a small piece in double over and over untill you're tired, but plex and acrylic will shatter before even a single bend.
        Polycarbonate safety glasses are more easily scratched than plastic lenses also.
        1. DanH | Jun 05, 2007 02:15pm | #20
          Just my experience.
  12. User avater
    SamT | Jun 05, 2007 07:43pm | #22
    Google "multiwall polycarbonate +flooring"
    SamT
    Praise the Corporation, for the Corporations' highest concern is the well being of the public.
