Library/Loft Ladder Ideas
Benji | Posted in General Discussion on March 14, 2008 04:52am
I need some ideas about constructing a library style ladder to a second story loft . I need to make it so it could lift out of reach of children. Any ideas ?
  1. OldGuy | Mar 14, 2008 06:03am | #1
    How about a fancy version of a fire escape ladder that slides vertically - out of reach for the youngsters (for a while at least!)
  2. Ragnar17 | Mar 14, 2008 08:19am | #2
    A different approach to moving/storing the ladder out of the way would be to make it inaccessible.  Actually, if you could just block access to the lowest four or five feet of the ladder, that would effectively keep kids (younger ones, at least) off the ladder.
    If you could find a way to make it aesthetically acceptable, all you would need is some sort of removable panel(s) to shield the lower portion of the ladder (for instance, hinged doors, etc.).
    Not sure if that's too far away from what you were envisioning, but I figured I'd throw the idea out there.
    1. Benji | Mar 14, 2008 02:54pm | #3
      Thanks , Those are in line with my thinking . I need to see pictures of something similar to see if I can make it work . Thanks again .
  3. BryanSayer | Mar 14, 2008 04:45pm | #4
    There are some library ladder manufacturers that advertise in Old House Journal. Probably FHB too.
    Anyway, if you just have the bottom fold up (kinda like an attic access ladder) would that work?
  4. frenchy | Mar 14, 2008 04:49pm | #5
    Benji,
     I have a similar need for access to my attic..  Code doesn't allow ladder access.   My solution was to make a book shelf with slide out trays holding the books.. ladder needed I slide out the trays  set them aside climb up and down the ladder the required # of times and then replace the trays holding the books..
     Oh those hand holds on the side? purely ornamental <wink>
    Create_Room | Jul 23, 2020 04:47am | #6
    Loft Stair Ideas – Loft Extension Stairs
    1. Bespoke Stairs
    Many people opt for bespoke stairs over a pre-made staircase for a more personal and unique design. All loft staircases need to be customized to a certain extent to fit the measurements of your home. Bespoke stairs offer a more impressive result, however. They’ll be made to order by a specialist joiner or manufacturer and are noticeable more stylish and better quality.
    2. Pre-Made Stairs
    If you go for pre-made staircases, these can also be very attractive and durable. Being scaled by larger manufacturers, rather than custom made, they’ll have a more economical advantage. Staircases produced by large-scale manufacturers tend to be quicker to build as well. It’s up to you what you decide.
    3. Spiral Staircase
    If your loft or landing is smaller and you need space-saving loft conversion stairs, a spiral staircase is a good choice. As well as being practical, they’re also a cheaper option. On average, a spiral staircase starts at £500 approx. to install.
    4. Paddle Stairs
    Paddle stairs are another great option for space-saving loft stairs ideas. These are made using alternating treads in the shape of a paddle. They take up a lot less space than conventional loft conversion stairs and also have a more unique shape.
  6. Frankie | Jul 23, 2020 09:42am | #7
    Bookcase ladders -
    Putnam Rolling Ladder Co.
    Telescoping ladder
    Attic access -
    Bessler Stair Co.
    Telescoping Stairs - Telestep.
    Hope this helps,
    Frankie
  7. User avater
    Mike_Mahan | Jul 23, 2020 12:10pm | #8
    Don't worry the kids are grown up now.
Grout-Free Shower Panels
  • A Postwar Comeback
  • Natural Simplicity
