lifting beams, use a screw jack?
m2akita | Posted in General Discussion on September 15, 2007 06:01am
Sometimes we need to lift up an overhead beam ( to replace a rotted post, replace old beam, etc.).  What we usually do is use a hydraulic bottle jack and a built up post ( usually a couple of 2×4’s nailed together).
This works great EXCEPT I do not like the hinge point that is created between the bottle jack and the post.  I think that it is an accident waiting to happen.  Your post is not perfectly plumb or the load shifts or something happens and that post and bottle jack go kicking out!!
So I am looking for a better alternative.  I would like something that I could throw in the truck and take to the job site.  In Mike Geurtin and Rick Arnold’s book “Precision Framing” they talk about using what they call a screw jack ( looks something like a lally column with a crank on it).  Doing an internet search couldnt find anything like they had, best I could come up with was a screw jack from Ellis ( http://www.ellisok.com/ellisok/products_screwjacks.html ).  Thinking about just using lally columns.  Anyone know how much lift you can get out of a lally column?  Also trying to think of how to make a solid/stiff connection between the bottle jack and post.
Anyone got any great ideas??
Thanks.
Live by the sword, die by the sword….choose your sword wisely.
    dedhed | Sep 15, 2007 06:30pm | #1
    Have a 1/4 inch metal plate welded to the top of the jack.Lally colum screw jacks are readly avaliale at home centers and local lumber yards.
  2. mike4244 | Sep 15, 2007 06:38pm | #2
    Concrete form supply houses carry what you need. Also you can easily make a screw jack. You would need a screw jack from a patent scaffold and a steel plate washer with a hole in the center a bit larger than the diameter of the screw jack.
    Build up a post with a space in the middle for the threaded portion of the jack.Place the jack in the hole. If the beam is heavy, use a piece of pipe for leverage on the jack handles.The post can be almost any length you need minus a portion of the screw jack. Do not raise anymore than 2/3 the length of the jack. Most screw jacks 18" or 24" in length. So you can raise either 12" or 16"high depending on the jacks length.
    Some screwjacks come without a footplate, this type can use a footplate or a U head.Uheads are made for a single or a double beam. The double beam type is the most convenient.It will take a beam almost a foot wide and can be used for a single beam also. When using a narrower beam ,twist the head so both sides of the U touch the beam. This will center a large U head on a smaller beam.
    I have used this for crawl spaces ( short post) up to about 9'-0.Lubricate the screw once in a while, WD 40 or grease.The steel plate is the size of the top of the post and the jack goes thru the hole. The plate is better bearing then wood and easier to raise.
    mike
    Edited 9/15/2007 11:41 am ET by mike4244
    1. m2akita | Sep 16, 2007 05:56pm | #13
      Yeah, I kinda was thinking about something like that also.  Kind of hopeing to get away from using any wood members though.  If I use wood, Ive got to store it protected somewhere ( and that means under a tarp for me), or that 4x4 or 6x6 is then gonna get used for something else.
      Hey, gotta complain about something :)Live by the sword, die by the sword....choose your sword wisely.
  3. byrnsie | Sep 15, 2007 10:01pm | #3
    I  lifted some steel I beams in an old carriage house to provide a center load bearing beam. We used studs to frame a guide built on the new lally footings then used a simple $40 cable pull from the Depot.  The guide kept the beams from swinging and we used blocks and 16D duplex to block the guide on the way up. The beam was pulled up to a double 2X6 plate at the top that we secured the guide studs to. Also we used HD canvas ratchet straps to crank it up tight at the end.
  4. VaTom | Sep 15, 2007 10:32pm | #4
    You musta missed the city auction last Tues.  They had a dozen or so tall electric screwjacks, meant for automotive lifting (one under each tire).  My machinist buddy bought 4 for $300 total if I understood him correctly.  Resold 3 as all he wanted was one heavy duty log lift for his sawmill.  Rated 6 tons ea, maybe a 6' travel.  Wheeled, so moving them was moderately convenient.  Second lift more difficult of course.
    Hydraulic bottle jacks don't always do what you expect.  Bad time for one to fail if you're under there.
    To get oak beams atop my 16' posts here, I clamped a pulley-supporting plank to the posts and ran a come-a-long over the pulley.  Pulling to a chain around the bottom of the post easily pulled the beams to the top, with the plank preventing over-pulling and missing the post.  Worked like a dream, solo.
    Speaking of beams, did you see craigslist this morning?  Half a dozen 10"x13"x22' oak beams, $175.
    1. m2akita | Sep 16, 2007 06:24pm | #15
      Yeah I missed the auction, but I always got you to remind me what I missed!!!  Saw the ad in craigslist, would be some nice lumber.  Got a project in the future that I might be able to use them on.  Have to think a little bit.
      1. VaTom | Sep 16, 2007 07:48pm | #19
        I didn't go to the auction either.  Carl told me what was there.  I figured it'd go high.  Oops.  But for my needs, the free-for-the-removal auto lift I got from a garage converted to restaurant is adequate.  And still uninstalled.
        If you need help moving (or storing outside) those beams, give a yell.  They're somewhere near here.  I've got metal roofing available for cover, tractor to sticker them.PAHS Designer/Builder- Bury it!
  5. JTC1 | Sep 16, 2007 01:10am | #5
    Sort of what dedhed said.
    Jack posts / screw jacks are readily available and relatively cheap.
    Went to Ellis site, their version incorporates a wooden column.  The jack posts which I have are comprised of two steel pipes which slide, one inside of the other.
    I have 3, Tiger Brand, J-S-100 jack posts, adjust from 4'10" min to 8'4" max; "tested to 9,100 lbs at max extension, 18,000 lbs at min extension". I paid about $30 each about 10 years ago.
    There are other models available both shorter and longer.  These adjust in 6" increments via a through pin system and the screw provides infinite adjustment between pin settings.
    Jim
    Google: "Tiger Brand Jack Post Company", HD listed as dealer, along with a lot of others.
    Edited 9/15/2007 6:16 pm ET by JTC1
    Edited 9/15/2007 6:25 pm ET by JTC1
    1. m2akita | Sep 16, 2007 06:29pm | #16
      Thats pretty much what I think Ill go with, the telescopeing jack stands.  Are you able to actually lift much with those jack stands though, or just hold at a certain height.Live by the sword, die by the sword....choose your sword wisely.
      1. JTC1 | Sep 16, 2007 11:39pm | #23
        Don't honestly know in quantitative terms.
        Have lifted several rather large porch roofs to replace columns and straighten the roof lines.
        Have lifted 8' span of attic floor joists + attic floor + stored attic stuff + roof and supported it to cut in headers, etc for garage door opening.
        Have lifted 4' span of 2 story house at the center beam to replace a cracked joist.
        Don't know what any of those things wiegh.
        You turn the screw jack on these with a 7/8" or so open end wrench and I have never really grunted on the wrench - grease threads before use for EZ lifting.
        Jim
  6. DanH | Sep 16, 2007 03:12am | #6
    I've done jacking several times with just the adjustable (telescoping) lally columns. (Why do people think that jacking a house requires a hydraulic jack??) Unfortunately, the cheap ones can be a bit unstable, but certainly more stable than trying to balance a bottle and a 4x4.
    The Ellis unit you linked to looks to be better than the telescoping lally. Of course you could buy four cheap lallys for the cost of one Ellis.
    As to how much range you can get out of a fixed (non-telescoping) lally, it obviously depends on the manufacturer, but I'd guess 6-8 inches is the norm.
    1. billybatts | Sep 16, 2007 08:25am | #10
      it says on the telepost box that the teleposts are not to be used for raising or lowering, the screw action is just for snugging up the post to the underside of the beam...i guess that is why people think that they need hydraulic jacks
    2. m2akita | Sep 16, 2007 06:31pm | #17
      DanH,
      How much have you been able to lift (weight wise) with the lally columns?  Sometimes we're lifting a good bit of weight.
      ThanxsLive by the sword, die by the sword....choose your sword wisely.
      1. DanH | Sep 16, 2007 09:18pm | #20
        I can't give you pounds, but have lifted ceilings/roofs several times, and done some jacking of sagging basement beams. Depends on the quality of the screw, and how finely threaded, of course, but I'd guess I've done 500 pounds with ease and 1-2 thousand with more effort. Probably about 2K is the limit for the cheap units, without having to use a hammer to turn the thing, while better quality ones should be good to about twice that.One big advantage of the screw lally, vs a hydraulic jack, is that you can give the jack a half turn daily for several days, vs having to jack all at once, when straightening floors, etc. Not a big deal for other types of jacking, of course.
        1. sisyphus | Sep 17, 2007 12:43am | #24
          I've lifted lots of things the same way.  I don't weigh it,  I just lift it. If its too heavy for one lally then I use several. I'ts often convenient to have at least two because one can lift then readjust one while the other holds the load etc.  Sometimes the threads can get roughed up but they're cheap to replace. I use cribbing and hydraulic jacks when I'm worried about stability or when the space is small.
          1. DanH | Sep 17, 2007 06:01am | #25
            Yeah, generally if it's heavy you'll want to support it in several places anyway. The lally jacks are cheap enough that you can do that and no have to shuttle a hydraulic jack back and forth between lift points, redoing the cribbing each time.
          2. rasconc | Sep 19, 2007 04:11pm | #36
            Another frightening thing with the bottle jacks is some seem to have a hair trigger release valve.  One little turn and it dumps.
            I just used some of the adj Lallys yesterday to replace a tapered column on a very poorly framed porch.  I used two about 18" apart for a kind of safety net and to make it easier.
            The box for my little ones say they are rated at 14k pounds, longet ones 9k, but I would bet they are talking about snugging up and supporting, not lifting.
  7. User avater
    Dinosaur | Sep 16, 2007 04:54am | #7
    For anything lower than 4 feet off the ground (and if configuration allows, such as for decks and verandahs), I use a JackAll to lift it. I've got a 4-footer; there is a 5-footer available. This is an extremely beefy jack that will lift a fully-loaded, full-size pickup so easily you'll hardly notice you're working. If the jack-beam will fit under the member you want to lift, it is by far the easiest way to go.
    Over that height, I usually do the actual lifting with a bottle jack and 4x4 plumbed up very carefully, but  I use adjustable (telescopic) steel pipe posts to hold up the beam while whatever work is being done is done (and sometimes permanently, depending). We're rarely lifting more than an inch, just enough to get the old column out and the new one in, and I never let the load stay on that setup more than the time it takes to insert a Lally (or the new wood post) and lower the beam onto it. We're talking a matter of 15-30 seconds here, usually.
    If I had to lift any more than, say, four to six inches, I'd be real tempted to set up cribbing caissons.
    Dinosaur
    foolish men call Justice....
  8. grpphoto | Sep 16, 2007 05:50am | #8
    Here's one. Use a 4x4 for the post above the jack. Make a sleeve from 1x6 or 2x6 material. This sleeve should fit loosely around the 4x4 and be nearly as long. Leave one side of the sleeve short to allow you to work the jack.
    In action, the jack pushes the 4x4 up through the sleeve, but the sleeve fits around both and will prevent the jack from kicking out. If the jack does try to kick out, the sleeve and 4x4 jam together pretty well and prevent any damage.
    I've had a jack kick out, and it's frightening.
    George Patterson
  9. RedfordHenry | Sep 16, 2007 06:19am | #9
    Lots of good solutions offered by others already, but I will add that whenever I need to use the bottle jack/post method, I always try to place the jack on top of the post, keeping the jack up near the weight being lifted.  Seems easier to keep everything aligned this way, especially when working alone.  If the post/jack combo looks wrong or is starting to "hinge", I feel that I have more control with the jack higher up.
  10. eleft | Sep 16, 2007 03:08pm | #11
    http://www.amazon.com/gp/product/B0000224PZ/103-3782850-1455854
    This is a handy thing too.
    I found it easy to adjust on a 2X4 for lifting or holding the other end or pushing that joist or rafter sister into place.
    It's a modified trailer jack.
    al
    1. DanH | Sep 16, 2007 03:30pm | #12
      Ah, that's a trailer tongue jack that's been adapted. Probably only good for 500-1000 pounds.
  11. dovetail97128 | Sep 16, 2007 06:10pm | #14
    Look into these.:http://www.amazon.com/Qual-Craft-2601-Wall-Jack-2601Q/dp/B0000224MY
    I have used them many times for raising beams.Plus you can then raise the house walls as well.
    "Poor is not the person who has too little, but the person who craves more."...Seneca
    1. m2akita | Sep 16, 2007 06:43pm | #18
      Ive got a pair of those and have used them to lift a beam into place before, but I dont think they have the lifting power to actually jack up a beam thats got a load on it.
      The farmer jacks that Dinosaur mentioned are nice for low loads, been thinking about picking some up just to have.Live by the sword, die by the sword....choose your sword wisely.
    2. DanH | Sep 16, 2007 09:21pm | #21
      That looks like the mechanism from a climbing scaffold.
      1. dovetail97128 | Sep 16, 2007 09:41pm | #22
        Dan ,
        Is is very much the same, uses the same principles to operate. Assume that each one can lift 1/2 ton safely, you can do a lot of lifting using them . I have jacked up beams in place, lifting floors or ceilings, roofs as the situation warranted.
        But I also own screw jacks, bottle jacks and one "box car jack" used by railroads for lifting box cars .
        What gets used is what fits the situation."Poor is not the person who has too little, but the person who craves more."...Seneca
        1. estacado | Sep 17, 2007 08:42am | #26
          can you post a pic of that 'boxcar jack'?
          1. seeyou | Sep 17, 2007 01:26pm | #27
            They're similar to the jacks that Dinosaur posted a pic of. Or at least the ones I've seen. http://grantlogan.net/
            I was born in a crossfire hurricane..........shooby dooby do
          2. dovetail97128 | Sep 17, 2007 03:23pm | #28
            estacado, I will have to get a hold of it . It is on loan to a friend right now."Poor is not the person who has too little, but the person who craves more."...Seneca
          3. dovetail97128 | Sep 17, 2007 04:01pm | #30
            estacado , Found a link to some that are very similar to what I own. Called a ratchet/screw jack. :http://www.hyjacks.com/mj113.htm"Poor is not the person who has too little, but the person who craves more."...Seneca
    3. DoRight | Sep 18, 2007 07:00pm | #34
      You mentioned using wall jacks for raising beams.  Are you able to run the wall jack in reverse to back it down ontop of your posts once you have raised the beam?  Most rachete type devises don't run in reverse.
      1. dovetail97128 | Sep 19, 2007 05:21am | #35
        DoRight,
        yes . I can and have done that . I suspect that OSHA would not appreciate the method used however. You have to lift just a bit to take up the load on the one "clamp" then tap the other "clamp" to loosen it and get it to slide down. It is not a smooth action at all, especially until one gets the hang of it, but it can be done."Poor is not the person who has too little, but the person who craves more."...Seneca
  12. edwin | Sep 17, 2007 03:46pm | #29
    Have you looked at post shores available from Ellis and others? They are also used for scaffolding and are sometimes rented out by scaffolding companies.
  13. FHB Editor
    JFink | Sep 17, 2007 05:37pm | #31
    I was looking for post-shore jacks like Mike Guertin and Rick Arnold use as well - found these: http://www.ablebuilders.com
    I remember the prices being good, and I think they would ship to me.
    Justin Fink - FHB Editorial
    "Everybody wants to know what I’m on...
    What I'm on? I’m on my bike, busting my ### 6 hours a day…
    ...What are you on?"
    - Lance Armstrong
    1. m2akita | Sep 18, 2007 02:32am | #32
      THATS WHAT IM LOOKING FOR!!!!!!!!!  I dont care what the guys ( and gals) here say about you.  You're it!!!  Im so happy I might even buy Mr. T some pants!!!!
      How did you find them??  I did all kinds of searches on the internet and kinda came up blank.  Ill try giving them a call tomorrow to see what kinda prices they quote.  Or do you want to order them, decide you dont like them, then give them to me??
      Thanks Justin, those are what I was looking for.Live by the sword, die by the sword....choose your sword wisely.
      1. FHB Editor
        JFink | Sep 18, 2007 04:32pm | #33
        I don't remember exactly how I finally found that company, but I was editing the article "six ways to stiffen a bouncy floor" (Guertin) and he mentioned using them over and over, but didn't have a source for them because his were really old. I couldn't show them in the article without giving a place to buy them, so I pulled my hair out just like you.
        ...so when I say I never ordered them, that's because I only really needed to know the source. That said, I do have a need for some and yoru thread reminded me to look into ordering a couple for myself. Justin Fink - FHB Editorial
        - Lance Armstrong
