Like MDF, but not a wood product?
zippynull | Posted in General Discussion on June 5, 2009 09:14am
Hi all,
Hope someone out there can help.
I’m looking for a sheet material with properties similar to MDF, but not based on wood fiber. Specifically, I’m looking for a rigid sheet, perhaps a plastic or composite, which can be cut and shaped using common woodworking tools (table saw, router), doesn’t fuse or crack during high-speed cutting and can be glued or fused together like PVC or polystyrene to make more complexed parts.
The closest thing I’ve been able to find is Veranda – the composite decking sold at HomeDepot – but it doesn’t come in sheets (AFAIK) and doesn’t quite have the clean surface properties I need. I’ve also tried sheet PVC, but it doesn’t have the kind of density I’m looking for.
Does anyone have a recommendation?
Thanks!
  1. Hiker | Jun 05, 2009 09:30pm | #1
    Azek may work for you, but I suspect it is similar to Veranda.  Comes in all kinds of sheet sizes and planks.
    http://www.azek.com/
    Bruce
    Sphere | Jun 05, 2009 11:07pm | #2
    Check McMaster-Carr  http://www.Mcmaster.com under sheet goods. You can get Phenolic Resin sheets in variuos thickness, Polycarbonate, UHMW , Teflon, and all sorts of composites like Cabon Fiber and such.
    I used a ton of Poly carb and Phenolic for production guitar templates and jigs.
    Start here and surf around.
    http://www.mcmaster.com/#plastic-sheets/=26s6dp
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
    Edited 6/5/2009 4:12 pm ET by Sphere
    popawheelie | Jun 05, 2009 11:56pm | #3
    Not sure if this will help. I ordered some for a bicycle project. Stuff is amazing.
    The prices aren't that bad. http://www.dragonplate.com/
    "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."
    Will Rogers
  4. MGMaxwell | Jun 06, 2009 01:41am | #4
    check Tek Supply @TekSupply.com for sheets of PolyMax. Comes in sheets from 1/16 to 1/2 inch thick. Up to 48 x 120 inches.
    1. zippynull | Jun 06, 2009 03:34am | #5
      Thank you everyone for all the recommendations!I need to do a little bit more research. I'm gonna take a closer look AZEK sheet and a couple of the product on McMaster. They look like the most promising for my application.Thanks again for all the help!
A New Approach to Foundations
