Lime Mortar Mix and Brick Pointing Tips
chefwong | Posted in General Discussion on May 21, 2002 07:11am
I want to have the exterior of my house cleaned and repointed. Am I missing any steps. This is what I plan to do in the following order
– Grind out 1/2 from all the joints
– Muratic Acid /Clean the Walls/Joints with Pressure Washer
– Repoint the joints
What’s a ratio needed for a lime based morter. I’ve been told that I will need to use a lime based mix as the house (about 65 years old) has softer bricks and to accomodate the softer brick, the morter has to be softer.
  1. wflather | May 21, 2002 03:49pm | #1
    I believe a pointing mix for soft brick would be:
    1 part portland cement
    4 parts lime
    8 parts sand
  2. rez | May 21, 2002 04:26pm | #2
    Alan-  I was reading where 3/4 inch deep was the recommended depth for the joint grind.
  3. tjcarcht | May 21, 2002 04:47pm | #3
    alan
    Unless there is something unusual going on, a 65-year-old house should not have soft brick and require high-lime content mortar.
    Portland cement mortars were universal by the 1920's.  You either have (1) an unusual situation (old brick?) and someone who really knows their stuff or (2) a typical condition and someone doesn't know what they are looking at.  You can try this simple step yourself if you can remove a small section of mortar:  pulverize to small pieces (this will be tough if it is portland cement-based, as would normally be expected) and place the pieces in a vinegar solution.  After a few hours, pour off the solution.  If you have a high-lime mortar all that will be left is the sand, for which you should be looking for a good match.
    Step 1 - if you have doubts, is ALWAYS, analyze the mortar and reproduce it in kind.
    Step 2 - make sure your mason knows what he/she is doing (similar work, references), etc.
    T. Jeffery Clarke
    Quidvis Recte Factum Quamvis Humile Praeclarum
    Edited 5/21/2002 9:52:25 AM ET by Jeff Clarke
  4. JCarroll38 | May 21, 2002 07:54pm | #4
     Alan, For information on lime mortar, go to: http://www.lime.org/.
  • A Closer Look at Smart Water Leak Detection Systems
