Looking for advise on selecting a linear propane fireplace that is non heating. Decorative only.
Thqnks
Thqnks
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Any sort of propane fireplace will produce SOME heat.
Spark Modern Fires was specified on my project. They sell a linear burner kit but you need to build the cabinet and plumb the gas line. Depending on where you are, a fan powered flue vent may be required.
Where are you installing your fireplace?
Fireplace
Coastal Georgia. If you put in a powered flue .......if fan is on , no heat,.....if off, heat. If not, is there anyway to configure a fireplace to achieve a heat/non heat goal.
thanks
