Linolieum removal from hardwood floor
| Posted in General Discussion on July 24, 2004 08:12am
I need to remove a small piece of glued on linoleum from a section of hardwood floor. I would like to preserve the surface of the hardwood as much as possible even though I am planning on putting down a glueless laminate. What are your suggestions?
    rjw | Jul 24, 2004 03:39pm | #1
    Heat (clothes iron) or cold (dry ice)
    Be aware that linoleum (or do you mean vinyl, or "vinyl asbestos tile" - the tiles used extensively in the 50's and 60s which we call
    linoleum") and the mastics used to glue them down can contains asbestos. (newer "straight" vinyl tiles don't contain asbestos.)
    Do not abrade the tiles or the matics.
    "It is as hard for the good to suspect evil, as it is for the bad to suspect good."
    -- Marcus Tullius Cicero, statesman, orator, writer (106-43 BCE)
  2. DaveRicheson | Jul 24, 2004 04:48pm | #2
    As Bob says age and type will dictate the removal method.
    On yinyl sheet goods glued with latex adhesive, you can peel the vinyl layer off of the backing. A spong  dampened with warm water will soften the remaining backer and glue enough to scrape it off.
    Older solvent based glues can be soften with a heat gun and then peeled/scraped up. Residule glue that remains will most likely have stained the hardwood, but since you are floating a laminate over it, won't be a problem. Several scotchbrite pads work for those stuborn spots that don't want to give up. Sandpaper glogs to quickly to be effective.
    Dave
    1. Pd5190 | Jul 26, 2004 08:25am | #3
      Pulled the linoleum up today and it came right off with minor effort except for the fact I have a 10 day old ruptured biceps tendon, that is a different story. So I will get with the scraper and hot water tomorrow and get the glue and a little of the backing that stayed down off. And as soon as I can get the furniture moved the laminate will be going down.
