Load bearing wall?
canon | Posted in Construction Techniques on November 6, 2007 07:19am
My wife wants to expand the kitchen and take out the wall with the dining room. Our home is an early 50’s ranch that has a median load bearing wall, that runs the length of the house between the two external walls and supports the end of the ceiling joists not supported by the external walls.
The wall we would like to remove is not this wall. My gut feeling is that is is not a load bearing wall as it runs parallel to the ceiling joists. What are the rules for determining if a wall is load bearing or not?
I do appreciate any and all help. Bob
    BossHog | Nov 06, 2007 07:24pm | #1
    There aren't really any "rules". You just have to look at each situation and figure it out.
    Looking UNDER the wall is a good starting point. If there's no beam under it, then it likely isn't load bearing.
    Looking in the attic will also give you an indication. If there's nothing up there that appears to be siting on it, then it's probably not load bearing.
    Our enemies have made the mistake that America’s enemies always make. They saw liberty and thought they saw weakness. And now, they see defeat. [George W. Bush}
  2. Piffin | Nov 06, 2007 07:40pm | #2
    based on what you say, it is not load bearing with regards to vertical loads
  3. dovetail97128 | Nov 06, 2007 08:57pm | #3
    ""What are the rules for determining if a wall is load bearing or not?""
    It is a load bearing wall if it is bearing a load from above it.
    That is the one and only rule .
    1. Piffin | Nov 06, 2007 09:37pm | #4
      that def discounts lateral and shear loads
      1. dovetail97128 | Nov 07, 2007 01:41am | #5
        yes it does. Shear walls take care of those. I have never heard the term "load bearing wall" applied to a shear wall despite the fact that they do carry the lateral load.
  4. JohnSprungX | Nov 07, 2007 02:01am | #6
    Here's a FAQ I wrote about bearing walls a few years ago.  It needs to be revised to add shear walls.  Either bearing or shear or both, you have to replace all the structural functions of a wall in order to remove it.
    -- J.S.
    How to identify bearing walls:
    When somebody asks how to identify load bearing walls, it's usually
    because they're thinking of removing a wall or cutting a big hole in
    one.  That can be serious business, not something that can be designed
    adequately by using a FAQ from the internet.  The following discussion
    may be useful for the preliminary speculation phase of such a project,
    but don't rely on it for anything more.
    Removing a load bearing wall is not impossible, but it is more
    expensive.  Often much more expensive.  It will require some sort of
    substitute support for the weight it carried, usually a beam.  Often
    this beam will have to be large enough that it extends downward from
    the ceiling fairly far.  On a top floor, you may be able to hide it in
    the attic, and hang the ceiling joists from the side of it, or even
    from the bottom.  But often the ugly beam sticking down, which always
    looks like you took out a wall, defeats the architectural purpose of
    removing the wall in the first place.
    You'll also have to provide adequate support under the ends of the
    beam, because the load that was formerly distributed along the length
    of the wall is now concentrated there.  This load has to be supported
    all the way down to the ground.
    The official code definition of a bearing wall is any wall that
    supports 100 pounds or more per foot of length, and any masonry wall
    that supports any additional masonry above its ceiling level.  That's
    not particularly practical or helpful, since there's no instrument to
    measure the weight on the top plate of a wall.
    In general, you have to look at what the wall supports, and what
    supports it.  Walls that are parallel to the joists above are usually
    but not always non-bearing.  On my top floor, I have a wall parallel
    to the joists that supports the rafter tails of a decorative roof
    section.  On the top floor, always look in the attic to see if the
    wall in question carries any roof load.  Then look to see if it
    supports ceiling joists.  If the joist tails rest on a wall, it's
    almost always bearing.  I have one exception to that upstairs, where
    the ceiling joist tails rest on a non-bearing 2x3 wall that was the
    partition between two closets, each 10 feet by 27 inches.  On each
    side, the real bearing walls are only 27 inches from this partition
    wall.  They form the sides of the stairwell.
    Taking that idea a bit farther, you may want to analyse the whole
    house, figuring out from the top down how the weight of all the
    materials and contents are supported all the way down to the ground.
    That's the way engineers design structures, from the top down.  They
    have to do it that way, because they can't design any part of the
    structure until they know the weight of the stuff it supports.
    In the past, certainly in the 1920's, building codes used to allow
    2x3's for non-bearing walls. Then for quite a while 2x4's were the
    minimum for all walls.  I know that started prior to 1971, but I'm
    not sure how far prior.  Now with the 2005 code, 2x3's are allowed
    again for non-bearing walls.  It's possible that you'll find a load
    bearing 2x3 wall if bootleg remodeling removed a nearby bearing wall.
    For ground floor walls, look in the crawl space or basement.  A
    bearing wall perpendicular to the joists should be no more than one
    joist depth away from some sort of support -- a girder or cripple
    wall.  That's a code requirement for all walls, not just on the ground
    floor.  So, if your joists are 2x10's (actually 9 1/4"), and a wall is
    10 inches away from the nearest support, it's probably not supposed to
    be bearing.  The exceptions are if the original design was done by an
    engineer, or the building is old enough to pre-date that code.
    In old houses, bearing walls parallel to the joists below may have no
    extra support.  In newer construction, they'll usually have a joist or
    two under them.  The best practice is two joists with space between
    them for utilities to run into the wall without hacking up the
    structure.  As always, beware of bootleg jobs that may have
    transferred loads to walls that legally shouldn't carry them.
    The tough part comes when you have three or more stories, and you want
    to work on the in-between floors.  First, you should start from the
    attic and work down, because any bearing wall up there has to be
    supported by bearing walls all the way down.  Then look in the crawl
    or basement, and work your way up.  As with the crawl space, the max
    is one joist depth away from floor to floor, unless it's an engineered
    design or an old building.  Next you may need to do some exploratory
    demolition of the ceiling to see what's on top of the wall in
    question.  Again you're looking for joist tails, this time floor joist
    tails.
    Finally, even if a wall appears to be non-bearing, if it's
    perpendicular to the joists above, you have to determine the size of
    those joists and the new distance they'll span if the wall is removed.
    If there are no walls or roof load supported by those joists, you can
    look in the span tables to see if the result will pass code.  If they
    support other parts of the structure, engineering calculations are
    necessary.
    Most people at this point should hire a structural engineer.  If you
    don't want to hire an engineer, get some engineering books from the
    library.  Unless you have a very strong technical and math background,
    that kind of light reading will probably convince you to pay somebody
    who already knows this stuff.  Even if you have the ability to learn
    enough for a simple job, an experienced engineer's second opinion may
    well provide you with a more cost-effective solution and save you more
    than the engineer's fee.
    Most jurisdictions will require a licensed engineer's wet stamp on plans
    before they issue a permit for structural work.  So even if you could
    learn enough to do it yourself, your local building department may not
    accept it because they don't have the resources to check your work.
    What you may be able to do for yourself is measure and draw.  If you
    can make good accurate measurements and drawings of what you have and
    how you want to change it, you may find an engineer who will do your
    job from your drawings, without the expense of a site visit.  Some will
    even do simple jobs via fax.
    A general contractor or rough carpenter might also be able to give you
    an expert opinion on whether a wall is bearing or not.  Please don't ask
    for a "free estimate" if you don't intend to hire someone for the job.
    The fair thing to do is pay them their hourly rate.  That might be about
    half what an engineer would charge for a site visit.
    Also, non-bearing is merely a legal term used in codes.  It doesn't
    mean that the wall in question has no structural role.  Gravity
    doesn't care whether we call a wall bearing or not.  After it's gone,
    the floor above may be less solid feeling, even though it still passes
    code.
    (Bearing Wall FAQ revised March 12, 2003)
Versatile Vise
