Locating the girder truss
| Posted in Construction Techniques on February 2, 2005 05:55am
Is there a correct answer for this one?
For a hipped roof built with engineered trusses, what determines the placement of the girder truss face that the hip trusses connect to?
Given a roof width, outside plate to outside plate, what distance back from the end should the truss engineer place the girder?
  1. Woodbutcher | Feb 03, 2005 06:54am | #1
    Boss hog?????????    You out there??????????????
  2. Blacky | Feb 03, 2005 08:17am | #2
    You need to go half the width of your structure to the face of the girder or measure your perpendular trusses and give the same overhang as your commons.  Have fun I've got some real nice (not) hip sets before.
    Dan
    edit;  The truss co shoulda sent ya a printout with layout on it.
    Edited 2/3/2005 12:19 am ET by Blacky
    BossHog | Feb 03, 2005 04:01pm | #3
    Like Blacky said, the truss company should give you a layout showing where it goes.
    There are so many ways to do hip ends that there's no right or wrong answer. It's very regional.
    I'd suggest calling a local truss company and asking them what they generally do.
    Bumpersticker: Honk if you love peace and quiet.
  4. blue_eyed_devil | Feb 04, 2005 06:28am | #4
    Gene, every designer has their own style. Probably the first rule of thumb is to make the girder a one ply because girders are more expensive than regular trusses.
    I just finished a 12/12 roof with four hipsets. All the primary jacks had a 6' run.
    I've worked on a ton of hipsets with close to 6' jacks.
    blue
    Just because you can, doesn't mean you should!
    Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
