locating under slab piping
DrJackpot | Posted in General Discussion on February 24, 2008 09:28am
I am a new subscriber to the on line Fine Homebuilding. My current project is a remodel of an existing bath with all the house drains (cast iron) under concrete slab. I searched for any information on pipe locating tools, equipment and techniques but came up with nothing. Can anyone direct me to information on this subject?
  1. ruffmike | Feb 24, 2008 09:41pm | #1
    I know for hydronic leaks, they run hot water and use a heat sensor, like fire departments have.
    In highrises when they have to find (avoid) pipes/ steel they have someone x-ray.
    I think in a residential job most would make an educated guess and start jackhammering.
    Either way, this will bump your post and get more responses.
                                Mike
    BillHartmann | Feb 24, 2008 10:47pm | #2
    Some plumbers (or drain cleaners) have the tv cameras and you put a transmitter on them and use a receiver to do a locate.
  3. plumbbill | Feb 25, 2008 02:34am | #3
    You could do the stethoscope method by creating a sound in the piping & use a stethoscope to see where it's the loudest.
    Or go get yourself one of these.
    http://www.ridgid.com/Tools/NaviTrack/index.htm
    “The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
  4. Riversong | Feb 25, 2008 02:46am | #4
    Find a dowser.
    Riversong HouseWright
    Design *  * Build *  * Renovate *  * Consult
    Solar & Super-Insulated Healthy Homes
  5. JLazaro317 | Feb 25, 2008 04:03am | #5
    I've got a utility locator. I can either put a tone in the pipe if it's conductive or drop a fish tape in it with a tone on it and locate it. Maybe a local excavator has one.
    John
    J.R. Lazaro Builders, Inc.
    Indianapolis, In.
    1. Snort | Feb 25, 2008 05:18am | #7
      Can you rent those things? I've got a little line I'm still trying to find<G> Winterlude, Winterlude, my little daisy,
      Winterlude by the telephone wire,
      Winterlude, it's makin' me lazy,
      Come on, sit by the logs in the fire.
      The moonlight reflects from the window
      Where the snowflakes, they cover the sand.
      Come out tonight, ev'rything will be tight,
      Winterlude, this dude thinks you're grand.
      1. JLazaro317 | Feb 25, 2008 05:42am | #8
        Beats me.....I bought mine off ebay a few years ago. Utility locating companies can't be trusted around here and after we spent about 4 hours hand digging on one job to find that the locates were 8' off,I bought the locator. I used it a couple weeks ago to find which way and how deep an existing sewer line ran before we dug it up. A tool that earns every penny I paid for it.John
        Indianapolis, In.
        1. Snort | Feb 25, 2008 06:43am | #9
          So, what kind is it?... sounds like I might NEED one<G> Winterlude, Winterlude, my little daisy,
          1. JLazaro317 | Feb 25, 2008 04:14pm | #12
            I've got a Metrotech 850. Lots of brands out there but I can't vouch for any of them. The Metrotech has been good. If you buy a set, make sure it has the tone generator and the locator.John
            Indianapolis, In.
          2. Snort | Feb 26, 2008 02:42am | #13
            Thanks, I checked ebay... there's quite an assortment. Winterlude, Winterlude, my little daisy,
  6. Snort | Feb 25, 2008 04:52am | #6
    I'm not sure if dowsing would work if there's rebar in the slab... but about anybody can dowse. Bend a couple of wires into ells, hold 'em in front of you and walk around. If they seem to move consistently, you may have found it<G>
  7. User avater
    popawheelie | Feb 25, 2008 07:55am | #10
    I'd call a good roto rooter service. I talked to one once and they send a snake down the drain with some sort of beacon on the end and sense it from above. Give them a call and i think they can mark them for you.
    1. DrJackpot | Feb 25, 2008 03:36pm | #11
      Thank you.  I did that and locally the cleanout people as well as the plumbers here don't trace.  There is one man who will do it but he wants $275 to show up.
        CapnMac | Feb 26, 2008 04:16am | #14
        That's the going rate here in my town (and $100 extra for "after hours"--like when else are you going have a leak under a slab?)
        Cannot imagine how same dude gets any plumbing work, since he's about 175% the rate of all the other plumbers in town, and that does not include after hours work).Occupational hazard of my occupation not being around (sorry Bubba)
      2. toolbear | Feb 26, 2008 04:51am | #15
        For less than having him show up, you can buy this Temp underground wire finder. We have one on the job. Love it. Very productive tool. If you can't tone the pipe (plastic), shove a fish tape down it and tone that.<http://www.valuetesters.com/Tempo-508S-Wire-Finder-Mini-Locator.php>The ToolBear
        "Never met a man who couldn't teach me something." Anon.
Grout-Free Shower Panels
