This is a feature I’ve done a couple of times in story-and-a-half houses. Basically, the first floor room ceiling has a narrow, dramatic “slot” along a wall or alcove, up to a Velux FS056. This shaft is pierced at the attic level to give light (through a translucent panel) to an attic or loft. Here they light a loft area –
Down the red one is an arched niche that the head of a big bed sits in – look uop and see the stars.
Green one looks down into a guest bath –
Here with my favorite glass installed – Flutex
HVAC return on the left pulls from the bedroom
And more things – All three pieces of the window seat are made from a $22, 36″ luan door slab, ripped into three pieces, with 1-1/8″ filler strips glued and nailed into the hollow edges. Mullions are just the structural 2x4s; windows were cut down from some free old windows
The “chair”-shaped structure on the right is a safety cover for the pull down stairway (normal access is up a ship’s ladder). It’s also made from some hollow-core door bits, and is held down from the underside with a couple of screen door catches. It can’t be removed from up top; you just fold the ladder down from below, unsnap it, and slide it forward – it’s light ‘cuz it’s hollow.
Edited 12/27/2007 7:50 pm by McDesign
Cool!
Appreciate the thrift.
You been watching those shows about how the ancient Egyptians lighted the interior of the pyramids/tombs again? I think its starting to rub off.
"It is difficult to get a man to understand something when his salary depends on his not understanding it." --Upton Sinclair
< Ancient Egyptians>
Yep!
Forrest - wondering about reincarnation
If we'd known this sooner, we would have had you change your sign on name to Imhotep. :)jt8
the blood red hole in the wall scares me ....
Buck Construction
Artistry In Carpentry
Pittsburgh Pa
You imagine sleeping, looking up that shaft?
that too!
Jeff Buck Construction
Pittsburgh Pa
