Anyone found a quick way to repair rotted faced logs due to carpenter ant infestation. Chisel and hammer requires much patience
Angle grinder? There are power carving tools, but doubt you can rent them. If you are careful and use the right chainsaw (being careful it doesn't kick back) I would think an electric chainsaw may work. Maybe a drill with a rasp "bit" would work. I think there are also power chisels.
I used an electric chainsaw to replace two log faces last spring,each replacement was hogged out to about the size of a 3"x8"x5' ,use cedar colored urathane chaulk and screws to go back with the inserts then stained to match.
You need a sharp chain and good footing , I made my cuts about 3" apart and used my framing hammer to knock out the pieces, then a wide chisel to clean up the bottom of the cuts. Took about 5 hours since we had some log ends allready on site.
