Guys, what do you use for a long straight edge… 12-15 feet range… maybe 20. I have some great aluminum screeds for my tilework, but the longest is 6 feet, and haven’t found anything longer.
Brian
_____________________________
HomeBase______________ LLC
Steel track with steel stud put into it to stiffen it. Chalk and laser.
Have a good day
Cliffy
Chalk line. Or lazer.
We are all in this together.
http://www.hay98.com/
I've got a couple of 8' Johnsons I use for tile work, and one of them is fairly new, so I'm certain they're available.
But in the range you're talking about, I can only imagine wrestling and hauling a straight edge around the length you're considering, all the while trying to keep it in shape to continue to be a straight edge.
On long tile layouts, you can run your sixes or some 8' end to end, lining them up with another.
Or the laser thing that was mentioned.
be portable!
An eight foot Johnson?!
Me too.
signed, John C. Holmes ;)
"Preach the Gospel at all times; if necessary, use words." - St. Francis of Assisi
Aluminum square tube... comes in 24' lenghts...
interesting idea. where do you find?
noticed frm your profile your in colorado... anywhere near grand junction? aunt/uncle live in a little town called Debeque, and I spent a summer out there when I was a kid. that's god's country out that way._____________________________HomeBase______________ LLC
any structural metal supplier or aluminium extruder...
Co springs area..
I know the area... Piffin's old stomping grounds...
that it is...
That's just where He goes to play
I used to ride horses up in the black forest area
you would not reconize the placew now...
That's what my cousins tell me. It was back in the early 70's I would go there, I'm sure it's quite different. Colorado Springs is a different world from what I understand.
watch for an alum storefront they are change'n out... or ck with a glass guy that my have an odd ball piece... you can usually find a 16' pretty easy
pony
I have seen some tile guys use a 16' piece of siding for a straightedge 12" wide Masonite by 16' made a nice straight line.
One thing that can work pretty well is steel struts (sold for hanging mechanicals). Not as light as aluminum, but less likely to get bent in use, and cheap.
