Looking for a Shallow 3 Gang Box
ArbrnEngr | Posted in Construction Techniques on June 2, 2007 01:25am
Here is the dilemma, a customer has a 3 gang switch that they would like moved onto a side panel of a refrigerator end panel. <!—-><!—-><!—->
Total depth is 1-1/2″.<!—-><!—->
That allows for breathing room between the fridge and the back of the box. <!—-><!—->
I can find the box I need in a single and double but not a triple.<!—-> <!—->
Any ideas? <!—-><!—->
  1. calvin | Jun 02, 2007 01:33am | #1
    Sorry for the delay.  If 1-5/8's would work.  Check Raco (hubbell-raco)  Now evidently you'll need a plaster ring for this box, but there's more to sort through.
    Product Datasheet View Image View Image View Image
    952 -- Gang Box, 3 Device, 1-5/8" Deep
    Product Specifications
     Box Type  RACO Steel Boxes
     Box Family  Multi-Device Gang Boxes & Covers
     Box Category  Gang Boxes
     Category  Gang Box
     Wiring System  Conduit
     Box Depth  1-5/8"
     Side Knockout(s)  4 concentric
     Bottom Knockout(s)  10 concentric
     End Knockout(s)  6, 1/2" & 4, 3/4"
     Drawn or Welded  Welded
     Number of Devices or Gangs  3
     Cubic Inch Capacity  60.0
     UPC Number  050169009529
     Product UPC-A Labeled  Yes
     Minimum Pack Qty.  5
     Carton UPC Bar Code  050169999523
     Inner Leaf 2 of 5 Bar Code  50050169009524
     Unit Carton Quantity  5
     Ship Carton Length (In.)  11.5
     Ship Carton Width (In.)  9.25
     Ship Carton Height (In.)  5.25
     Weight (Per/C)  158
     Pallet Quantity  720
     Dimension A  1-5/8"
     Dimension B  8-3/16"
     Dimension C  8-5/8"
    http://www.quittintime.com/
    Edited 6/1/2007 6:38 pm ET by calvin
    SamT | Jun 02, 2007 04:04am | #2
    You can also check RV supply and repair shops.
    SamT
    Praise the Corporation, for the Corporations' highest concern is the well being of the public.
  3. MSA1 | Jun 02, 2007 04:22am | #3
    Judging from some of the things I see in walls, i'd say just forgo the box! Screw the switches to the drywall and call it good.:>)
    1. DougU | Jun 02, 2007 05:38am | #4
      Hell its the side panel of a fridge unit, much better holding power then the drywall!
  4. grpphoto | Jun 02, 2007 05:49am | #5
    IIRC, I bought some gangable outlet boxes at Home Depot (I think) last year. They are 1.5" deep. I had to remove the side plate from each one and drill them for conduit, which is why I remember them being gangable. If you can't find them at HD, try Lowes, but I think I found them at HD.
    George Patterson
    1. ArbrnEngr | Jun 02, 2007 07:24am | #6
      THX for the ideas, HD and Lowes are a no, but excelent Idea about RV's and I have a shop about three miles away.
      1. allaround | Jun 02, 2007 07:49am | #7
        Any good electrical supply house should have the gangable switch boxes with the removable sides.
Versatile Vise
