looking for Baltic birch in E PA
unTreatedwood | Posted in General Discussion on September 19, 2005 09:25am
We just moved to E. STroudsburg area and am unable to locate a source for 1/2″ Baltic birch.  Anyone out there in the area have a source for me in the I-80 area in east PA?  thanks.
    DDay | Sep 19, 2005 10:09pm | #1
    This might help.
    http://www.woodfinder.com/
    1. unTreatedwood | Sep 20, 2005 03:53pm | #2
      thanks.  closest on this website is 154 miles away!! ouch.
        DDay | Sep 20, 2005 05:09pm | #3
        In my area, Massachusetts, some of the trim carp's and small cabinet shop get their stock from higher end molding and trim suppliers.  Where you are in Pa, there has to be a place closer than that.  Call a few of the local cabinet shops and ask if the re-sell, they might, but if they don't, ask who is a good local supplier, most will give you that info.
        1. unTreatedwood | Sep 20, 2005 07:24pm | #4
          just found a supplier near where I work in NJ.  Big relief... thanks.
  2. NPitz | Sep 20, 2005 08:13pm | #5
    Try Russell Plywood. They have a branch in Reading that may service your area. Their number is 1-800-787-7355. If that doesn't work out, try calling local cabinet shops and asking where they get their sheet goods. There is almost certainly a distributor that everyone buys from in your area. You may run into a problem just buying one sheet from a distributor that you don't have an account with, though.
    1. unTreatedwood | Sep 27, 2005 05:42pm | #7
      I will do so.  THanks.
  3. joeh | Sep 20, 2005 09:45pm | #6
    Same answer, ck with local shop. They are all getting delivery from somewhere.
    Not what you asked, but Monday I paid 1/2" 5 sheets $108.13, 5 sheets 3/8" $88.75, 5 sheets of 3/4" $167.25. More by the single sheet.
    Joe H
    1. unTreatedwood | Sep 27, 2005 05:44pm | #8
      that's about what I have seen in the past.  right in line, in fact.  As it turns out, HB Casterline has all the Baltic birch and hardwood VC plywood I need.  right around the corner from my work.  thanks.
  • A Grand Rescue on the Coast
